Power light flashes several times when turned on (screen stays blank and no sound) then turns red and flashes 5 times. Just repeats the 5 red flashes. Nothing else seems to be happening.
Check out the single capacitors placed on the board.it would have blown off.
5 blinks means check video out and C board, probably faulty convergenbce. You are going to need a technician to fix this.
Here is the detailed error code solution:
Five blinks - AKB circuit (automatic kine bias), the
timer/standby indicator blinks for about 30 seconds then goes to the
self-diagnosis function. Something is wrong with the video. Check video
out, Q705, 732, 761 and other components on the C board, also check
Q218, 219, 220 on the A board. In addition, unit could be in IK
blanking, try turning up screen slightly.
from techlore
That means that several components on convergence, output and power board must be tested.
You will probably need a technician to fix this, since there is need to test several ICs reading voltages and testing continuity on resistors.
