Televison & Video Logo
Posted on Dec 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vivitek RP56HD22A 56" HD DLP TV. When the TV is turned on the picture stays on for about 30 secs and the TV then cycles off and then back on. It does this repeatedly. Picture quality when it does come up is still very good, it just won't stay on. I've reseated the lamp which looks good. Cleaned the filter. Cooling fan seems to be working fine. Trying to determine if it's the ballast or power module. What do you think? Rick, Virginia
AMJAD HUSSAIN
Level 3:
  • Master 586 Answers
  • Posted on Dec 05, 2008
AMJAD HUSSAIN
Master
Level 3:
Answers
586
Questions
Helped
205859
Points
1533
HI,
   Check the capacitors in the main power supply board.There must some leaking or blast capaciotr.Check and change the capacitor.And your tv works fine.
Thanks
Anonymous
Level 2:
Sergeant:
  • Expert 276 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
276
Questions
0
Helped
66157
Points
683
Most probably its the issue of short power module in the unit.get it repaired.if not possible needs to be replaced to resolve the problem.
Anonymous
Level 2:
Sergeant:
  • Expert 217 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
217
Questions
0
Helped
58079
Points
537
The components gets heated up on the board so this is happening so it is necessary to get the board chevcked.it could also happen due to loose soldering.dry soldering the whole board can also help.
Lost the color red
theres a digital module that comes with the light engine..but your gonna spend some dough..probably only available with a complete light engine replacement..sry
I need A color Wheel for vivitek DLP RP56HD22A
I need the same part. Did you ever find one? Any recommendations
I replaced the lamp im my vivitek 56 inch dlp tv. But it still wont turn on. The light goes from green to red and it makes a sort of high pitch sound then stops
my vivitek RP56HD22A 56" dlp tv has a new lamp and will not turn on. when i push the on button is whines and wont come on
I have a 52" rear projection vivitek dlp tv. Picture is fine, but it has a loud humming sound. Does anyone know what it is or how to fix it??
turn on video mode if loud humming still occurred replace filter capacitor on audio section from your tv ckt board.
I have a 61" samsung dlp. It worked fine
Start with replacing the lamp. Then move on to the Ballast. Then the color wheel. Then the Power Supply. One of those parts should fix it. If not call back.
1helpful
Vivitek 56 inch dlp projection is humming. why and how to fix
In my experience, the humming means your color wheel is going. The bearings inside the wheel are probably giving out.
My Vivitek started humming a couple of months ago and first I replaced the lamp.
Still hummed.
I read in other forums that humming is linked to color wheels and that seemed like where the noise was coming from.
I purchased a new wheel online and replaced it myself...
..no more humming, the picture is great and now I can listen to the movie again...not the tv!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
