Time warner cable remote ur5u-8700L for a Auria
SOURCE: time warner code for Fujitsu 42" tv
I have the 55 inch. try using 246. That works on mine. if not try 028,164,208,066
let me know if that works for ya
ric
another note, are you using the flash on the back of your cable box or do you have a sensor in front of the DVR box?
SOURCE: how do i program my new tv code into my time
Go to the time warner website, they should have accessory section there page, and there you find codes.
SOURCE: i need a code to make my time warner remote
According to timewarnercable.com, the codes for a toshiba tv are 074, 168, or 170.
If none of these codes work, I suggest you try the code search function. To do this, follow the steps listed below.
1. Turn on the tv
2. Press "select" and "tv" together until the LED blinks twice.
3. Using the keypad on the remote, type in the digits 9-9-1. This will open the "code library." The LED should blink twice.
4. Press "power."
5. Press "channel up" key repeatedly until the tv switches off.
6. When the tv turns off, press "tv" on the remote to lock in the code.
Your remote should now be programed to your tv.
I hope this helps, and good luck!
Sincerely,
Der Strom
