I had a viper 5704 installed but the remote start does not not work properly. I get a remote start error on the remote and eight parking light flashes from the vehicle. I did get it to work by getting into the car turning the key to the On position and pressing the brake pedal. I then took the key out exited the vehicle nd the remote start then worked fine. Any ideas on what the problem might be. I have a 2012 honda odyssey and everything else with the viper system works fine.
SOURCE: My Viper 5701 has been
Check to make sure that the valet is not engaged. The alarm will notify you by having a constant lit light. If the light flashes like it should open a door and check to see that the light blink on and off as if the alarm were triggered. If this happens the your problem is with the siren, just have it replaced.
SOURCE: i had a viper
If your vehicle has daytime running lights they will be on when remote started no real way around that try leaving your parking brake on.
The new vipers default setting is constant rather than flashing.
SOURCE: problem with my viper alarm system on my 98' odyssey
first, you need to manuslly disarm the alarm. open driver's door, put key in ignition, turn on ignition, an then within 10 seconds push the valet/program button for a couple of seconds. (it is the little spring loaded push button that they installed with your system. probably in the kick panel or under dash
SOURCE: Viper alarm, lights dont flash
Sounds to me like the parking light output wire. They usually have a seperate fuse or the connection is bad. The connection on your vehicle should be behind the pass side kick panel and look for a wire to the white/purple wire and check that with a meter or light to see if it's kick out power. There is a possibility they used the negative trigger through a resister and that would be located behind the headlight switch. That will at least let you know and trace down the problem. Here is a link with that parking light info for yours. Hope this helps and let me know if you have more questions.
http://64.85.6.121/diagrams/printpage.asp?ModelID=17258&MakeID=16
SOURCE: how to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
