Konica Minolta Magicolor 1600W Printer Logo
Posted on Sep 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After installing the new cartridge into the printer, the toner indicator (orange), and slowly all the while blinking. Ready indicator light is green! But the printer does not print. In the printer status monitor says "NO ONE TONER CMYK"! But it shows how much interest is left in each cartridge toner. In another printer cartridges are working properly! Help!
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Apr 28, 2019
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1912207
Points
11959
Replace the toner cartridges with OEM toner
2 Related Answers
Anonymous
  • 14 Answers
  • Posted on Sep 08, 2009
SOURCE: Streaks & Smears after changing toner cartridge.
Remove all of your toners and clean them off. Replace each one and make sure they are well setted in the unit before going to the next one. Make sure the carosel turns smoothly and nothing is hanging up on the sides. Reboot the whole printer and let it settle for 5 mins before printing. toners come lose sometimes when you turn carosel around. Hope this helps you these printers are a ***** to deal with ,but when they are right there great.
Anonymous
  • Posted on Jan 14, 2010
SOURCE: minolta 2430dl X toner not installed
I had this same problem and discovered the CORRECT solution!! The Crum reader is not the issue. That is for reading the level of the toner and telling the printer when iti is low or out. The "Cartridge not installed" issue is caused by poor contacts on the LEFT side of the printer. Look at the toner cartridge on the LEFT side as you are holding the colored cartridge latch. Thos two copper contacts make contact with the 'springs on the left side of the cartridge holder. I user an eraser, alcohol and air to clean the contacts on the toner catreidge but ESPECIALLY the spring contacts on the outside of the cartridge holder. You should clean all four. I went a step further and took the left circuit board off, clean all the "spring contacts and took the black holder with long copper contacts out and cleaned those. The printer is now like a brand new printer. No errors at all!!
My printer is blinking green light in every 5 seconds. i am give test print but is not came to print
Ready and Error Lights (EPL-6200L only)
The Ready (green) and Error (red) lights on the top of the printer may be the first indication of trouble. The status of the lights, on, off or flashing, indicates your printer status, as described below. The Status Alert window in the EPSON Status Monitor 3 utility indicates what type of error has occurred and offers you a possible solution. Look through this section to find the kind of problem you have, then try the recommended solutions in the order they are presented until your problem is solved.
a. Error light (red)
b. Ready light (green)
Status/Error/Warning
INDICATOR LIGHTS
Ready
Error
Service Required (controller error)
OFF
> Service Required (engine error)
> > Service Required (protocol error)
> > Output Paper Jam
> > Paper Jam
> > Paper Out/Feed Jam
> > No Developer Cartridge Installed
> > Wrong Developer Cartridge Installed
> > Installed Developer Cartridge is Not a Genuine EPSON Product
> > Developer Cartridge Memory Error
> > Toner Out
> > Front Cover Open
> > Output Cover Open
> > Printing on Incorrect Paper Size
> > Unsupported Paper Size
> > Time Out Error
> > Insufficient Memory to Print Current Page
> > Paper Size Warning
> OFF
Not All Pages Are Printed
> OFF
Warming Up
> OFF
Replace Photoconductor Unit
> OFF
Toner Low
> OFF
Installed Developer Cartridge is Not a Genuine EPSON Product Warning
> OFF
Sleep mode
> OFF
Ready
> OFF
Printing
> OFF
Processing Data
> OFF
> Note: > If the problem remains after trying the suggestions in this section, contact your dealer or a qualified service representative for assistance.
Control panel: Error light on
A controller error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If all the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready and Error lights flashing
A print engine error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready light flashing, Error light on
A protocol error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Output Paper Jam
Control panel: Ready and Error lights on
Indicates that there may be a paper jam inside the printer. Open the printer's output cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Jam
Indicates that there may be a paper jam inside the printer. Open the printer's front cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Out/Feed Jam
Indicates that there is either no paper loaded in the printer, or there is a paper jam in the feed slot.
If no paper is loaded, load paper into the MP tray, then open and close the printer's front cover. See Loading Paper for instructions on loading paper.
You can clear the error by pressing Continue on the EPSON Status Monitor 3 window that appears.
If paper is loaded, then there is a paper jam in the feed slot. See Clearing Jammed Paper for instructions on clearing paper jams. The error is automatically resolved upon clearing the jammed paper and opening and closing the printer's front cover.
Either the developer cartridge is not installed or is installed incorrectly. Check to see if the developer cartridge is properly installed and follow the instructions under Developer Cartridge to install or reinstall it.
Either the installed developer cartridge is defective, or it is not the right one for your printer model. Replace it with a new or correct developer cartridge by following the instructions under Developer Cartridge.
Control panel: Ready light on, Error light flashing
The installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
To continue using the currently installed developer cartridge, press Continue on the EPSON Status Monitor 3 window that appears to clear the error.
A memory read/write error has occurred. Try reinstalling the developer cartridge or replacing the current cartridge with a new one by following the instructions under Developer Cartridge. If this still does not resolve the problem, turn the power off and then on again.
Toner Out
The developer cartridge is out of toner. Replace the developer cartridge by following the instructions under Developer Cartridge. To clear this error and print a single sheet, press Continue on the EPSON Status Monitor 3 window that appears to clear the error. After that, this error will occur again until the developer cartridge is replaced. If you set the Toner Out Error setting to Off, you can continue printing even when this error occurs.
Front Cover Open
The printer's front cover is open. Make sure that the printer's front cover is closed properly by opening and closing it again.
Output Cover Open
The printer's output cover is open. Make sure that the printer's output cover is closed properly by opening and closing it again.
The paper loaded in the paper source does not match the required paper size. Replace with paper of the correct size and click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
The specified paper size is not supported by this printer, or the paper feed direction is incorrect. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Time Out Error
Data transmission from the computer to the printer is interrupted and a timeout error has occurred. Click Print Again on the EPSON Status Monitor 3 window that appears to resume printing. If printing does not resume, or if you want to change printer driver settings, click Stop.
The printer does not have sufficient memory to print the current page. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Paper Size Warning
The size of the paper that fed through the printer does not match the specified paper size. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
This warning is displayed if an Insufficient Memory to Print Current Page error has occurred while Auto Continue is set to On. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
Warming Up
Indicates that the printer is warming up to process and print data.
Control panel: Ready light flashing (flashes at longer intervals than usual)
Indicates that the photoconductor unit is close to the end of its service life (less that 5%). Prepare a new photoconductor unit to replace the current one. See Photoconductor Unit for instructions.
To temporarily dismiss the warning, click Close on the EPSON Status Monitor 3 window that appears. Resetting the photoconductor unit also clears the warning.
Toner Low
Indicates that the developer cartridge is nearly out of toner. Prepare a new developer cartridge to replace the current one. See Developer Cartridge for instructions.
This is a warning to inform you that the installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
Sleep mode
Indicates that the printer is in energy-saving mode. The printer goes into standby due to inactivity. If the Sleep mode is enabled, the printer goes into standby in 15 minutes.
Ready
Indicates that the printer is ready to print.
Printing
Indicates that the printer is printing data.
Processing Data
Indicates that the printer is processing data.
tip
Printer error (orange or blinking light)
<b>Printererror (orange or blinking light)</b> After your printer has completed its initial startup you shouldhave a solid green light. If the light indicator is blinking or orange oftenthis is an indication of a printer error. For example, this could indicate a paperjam, issue with the ink or toner cartridge, or other serious error. Because there is no standard to what a blinking light or orangelight means if you're getting either of these we suggest referring to theprinter documentation for troubleshooting steps or methods of determining whatthe status indicator is reporting.
Hp laserjet 1320 toner empty?
you might try a recycled cartridge and have a lot less invested.Sounds like your cartridge is empty.Is print quality bad or light?
3answers
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
All four toner lights blinking
it could be that you need to replace all the toners. I do not own this kind of printer, but if it is the same as my inkjets, you have to replace all empty cartridges or it still wont work. try replacing the other toner and see what happens.
Solution for samsung ml 1911 printer bliking red and orange lights
  1. The blinking red light of the printer indicates that a minor error has occurred in the printer. The printer usually resolves the error within a few minutes.
  2. If the light keeps blinking check if the toner cartridge is low, redistribute the toner for the time being.
  3. Order a new toner and replace the existing toner if the issue persists.
  4. If you see the solid red light, clear any jammed paper. Pull the standard paper tray out and make sure the paper is placed correctly.
  5. Check the manual tray as well and remove any torn paper bits stuck in the tray.
  6. Make sure the printer's front cover is closed. Make sure the toner cartridge is installed correctly.
When printer is turn on that time printer reddy and cartridge light on so what is the problem
You can see four LED's on control panel, from top to bottom,1st is toner indication 2nd Attention 3rd is Ready light, 4th go light.. Observe led's are 'blinking' or 'On' condition.. # If toner light is blinking ="toner cartridge missing or contact problem or memory faulty.
# If toner light & ready lights are on= "toner low indication or refilled cartridge loaded".
Lexmark e260d printer 4th light orange is continuously flashing. New toner cartridge was installed. Not printing
If the blinking light is on Toner Low (4th light starting from left), press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
For further assistance, please contact Lexmark Technical Support
The top light of the two is flashing green/red back and forth very fast and the light on the bottom is a solid red. how do I fix this so that way it will work normally
The steady lower light indicates the unit needs a new toner cartridge, MLT-D108S. Did you previously see this light blinking or blinking rapidly? (Those indicate the toner being low.) Replace the cartridge and check for any other error lights. Turn off the machine and let it cool. Then open the front cover and pull the old toner cartridge. Open the package with the new cartridge, remove the packing tape and paper that protects the cartridge and gently shake it (avoid touching the blue or green parts of the OPC drum). Press the cartridge into the slot until it is fully seated. Close the front cover.
The green/red blinking power light is not one I'm seen before. The printer indicates a non-toner failure (open cover, no paper, LSU failure, etc.) with a steady red light.
Says ready, error light blinking, vertical non-print line
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
