SOURCE: Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
SOURCE: homelite st-175g trimmer
This is for a duel line trimmer. I hope this will help.
Cut two separate pieces of string, about 7 ft. each.
Stick the end of
the line in the hole on the inside of spool.
Wind clockwise onto spool,
putting the line that is closest to the ground on first.
Once you have
winded this piece on, lock the last 4 inches of line through the slits
on spool.
Repeat process for second piece of line, locking the last 4
inches in slot opposite the other locked in piece.
Put the spool on the
trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the
locked position. Put cap on and GO CRAZY!
Jim
SOURCE: Homelite Trimlite String Trimmer. String won't advance on tapping
remove assembly clean with soap and water and toothbrush(make sure when you dissasemble make notes of how to put back together!)Check spring make sure not broke or distorted-oil with silicon oil(walmart sells or auto parts store)reassemble reverse of dissassemble!!! hope this helps you!!!!
SOURCE: I am looking for a manual for a homelite gas
type in homelitest and ut number on the trimmer and then search google . maybe
SOURCE: How do I feed string into my Homelite Mighty Lite
cut a 6 ft piece and wind it (starting with the middle of the trim line) around the head with each head going opposite directions. When you get it wound up, you will have two pieces sticking out in opposite directions and they can be clipped into the small plastic slots on the edge of the string canister. THen press the ball on, and attach to the trimmer.. Just keep the string the grooves and you will be fine...
OHYEAH!!! dont worry if it keeps coming unwound or pops off the trimmer at first, it will happen until you develop the technique needed for a quick replacement
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Testimonial: "Thank you! Your response helped me troubleshoot."
