The wine cooler goes no lower than 23 degrees
Well, I'm not sure what your actually trying to do, but the whole purpose of a wine cooler is to cool, not to freeze and the temperature should really get no colder than 34 degrees F.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
SOURCE: Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
SOURCE: Avanti Wine cooler Model #
I had this issue and it had all to do with ventilation. If the fridge is in too tight of a space without any type of air space this will be the result. I was able to cut into the cabinet behind the fridge and put a 18" x 18" grate that allowed air to move. Problem solved!
SOURCE: Danby wine cooler model dwc172bl thermostat replacement
my danby dwc172bl wont get cool what to do
