E5 code comes up on the display sometimes after 5 to 10 mins use sometimes does on after a few seconds of switch on. Anyone know what the error code means and what i can do to fix please.
SOURCE: body sculpture BT2710 instructions
hi if you email body sculpture on [email protected] they will send you a free manual by pdf they are brilliant i know because i have used them for the same reason myself last week
Jules
SOURCE: Hi, have lost the manual for my treadmill York
Error 7 is a Safety Key Error....
That's the red circular magnetic insert that slots into the front of the console...
The manual says : Simply secure the safety key in place and then
try again..
hope this helps
SOURCE: Sportcraft TX 2.5 treadmill - error code 3 - stops
Sorry I dont have the solution but I have the same problem.
Read somewhere that Sportcraft control boards had
a design flaw.
SOURCE: E2 Code on Treadmill after starting
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
