My son inlaw couldnt start his car cause of a flat battery so put a charged battery in to start it then when it started he took battery out and put his one back in while it was idling but put it in wrong way around LOL now he has no power at all to anything .? what should he do ? can it be fixed diy ?
SOURCE: Car battery won't stay charged.
jumped battery started next day attempted to start and was dead i swapped out a battery no good then i swapped out the terminals to the battery and it started right up
SOURCE: CAR WON'T START
do the dash lites come on when the key is turned on? do you have a good connection at battery? is it in park? what were you trying to repair initially?
SOURCE: I have a vw passat 1999 1.8 T wont idle when started
i suspect the throttle body has lost its basic settings for some reason,ive only known of that happening a few times tho,but that is the symptoms of a throotle unit,plug in a scanner check the codes and reset the throttle body in basic settings
SOURCE: Charging problem.. Wont charge battery
The instructions for installing a new alternator usually read to fully charge the battery (12.3 - 12.8 volt range). Otherwise, the alternator will be damaged when it initializes. I have seen some extreme damage result from installing a new alternator with a low-charge battery. The torque required to turn an alternator when damaged in this scenario is unbelieveable!
SOURCE: 1998 mitsubishi mirage 1.5 liter 5 speed wont start
If you have spark, try changing the fuel filter. If you don't have spark, get back to me.
