PUK CODE TAKEN FROM THE SIM OPERATORS.YOU CALL THE COUSTOMER CARE ASK THEM THE PUK CODE AND UNLOCK THE SECURITY CODE,REMEMBER IF YOUR ATTEMPTED TO BREAK THE CODE AFTER 3 CHANCES YOUR SIM WILL BE BLOCKED AND THEREFORE NEED TO TAKE A NEW SIM IN THE SAME NO
PUK codes can be obtained through the following ways -
The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider. Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
sir please call to the related simcard customercare and say the last 6-digit number which is present before the simcard. then they will give the pukcode number to unlock the cellphone...........
PUK stands for Personal Unblocking Key. This is a uniqueeight digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider. PUK codes can be obtained through the following ways -
Hello i hope u 'll be fine.... thanks for using
fixya.
As soon as you type three times wrong security codes,
the phone
gets blocked and ask u for the PUK.
Simple solution is go to your service provider to
unlock that code, They 'll unblock the PUK free, Then u 'll be able to
access your phone without the
security code
Hi, three wrong entry of PIN code will result in SIM blocking. Once SIM gets blocked, phone starts asking PUK code to enter. If you again enter wrong code for three times, SIM gets completely blocked. You have to walk into your service provider outlet to get a replacement SIM card. PUK code is a SIM specific code assigned by your service provider. No way you can guess & enter it. So, when it asks for the PUK code, don’t do anything, get the PUK code from your service provider. Call to customer care using any other mobile phone which uses the same service provider. They will ask some details about you to make sure you are the owner of the SIM card. Questions might include your billing address, email ID, numbers you recently called or messaged etc. They might even ask you number printed on the SIM card, so be prepared with all details before calling them. Once you get the PUK code, enter it into the phone & your phone will return to normal. Good luck!!!
>0132025578
