Question about Texas Instruments TI-84 Plus Calculator
INVALID DIM Whenever I attempt to graph an equation, regardless of its simplicity, I receive the error message "INVALID DIM". I checked the mode and the stat plot menu and nothing appears to be out of order...the graphing function just seems not to work.
  • 23 more comments
  • Anonymous Dec 05, 2007
    Went through the mode settings.
  • dasskiss May 21, 2008
    im trying to use the Linreg(ax+b) thing, and then it appears a invalid dim, i have already tried the statplot of, but it won`t work for this particular problem
  • Anonymous May 26, 2008
    i'm trying to figure out the equation for a wave, and my teacher told me to use Sinreg on the TI - 83 plus, but when ever i try to use it, i get invalid dim. what am i doing. please keep in mind, i have not yet learnt trig, and i'm just in algebra II.
  • Anonymous Aug 21, 2008
    same problem
  • calhottie123 Sep 03, 2008
    I have a TI-83 plus and i am tryin to put equations in to my y= but it keeps sayin invalid dim. what do i do to fix it.
  • A SUET Sep 27, 2008
    yeah, same here. I just got a TI 84 plus silver. And when I try making a graph, it shows me an error called INVALID DIM
  • Anonymous Oct 14, 2008
    everytime i graph it says invalid dim
  • Anonymous Oct 19, 2008
    I try to graph a function and it just comes up invalid dim??
  • Anonymous Nov 12, 2008
    Everytime i try to graph is comes up saying error Invalid DIM
  • Anonymous Dec 04, 2008
    everytime i try to graph it comes up invalid dim
  • Anonymous Dec 09, 2008
    OH MY GOODNESS I LOVE YOU!
  • Anonymous Jan 29, 2009
    Whenever i go to graph no matter what it says Invalid DIM
  • allaurewiz Feb 03, 2009
    i cant plot my graph it keep saying INVALID DIM
  • Anonymous Feb 23, 2009
    when i type ,y function into y = and press graph i keep getting "ivalid dim" how do i fix that???
  • Anonymous Mar 18, 2009
    every time i try to graph something it doesn't work and says invalid dim. need help please
  • jennayy Apr 29, 2009
    The same thing keeps happening to me. I turned all my stat plots off, but it still shows the same error on the screen whenever I press the graphing button or y= button. Is there anything else i can do?
  • Anonymous May 06, 2009
    this happens when i use my calculator also.
  • btjymkgu
    btjymkgu Apr 23, 2017
  • btjymkgu
  • govind Sen
    govind Sen Oct 30, 2017
  • govind Sen
    govind Sen Jan 13, 2018
  • Anonymous Mar 02, 2018
    The Telangana State Government holds Telangana Eamcet Entrance every year to all the applied applicants; the Jawaharlal Nehru Technological University (JNTUH) conducts the TS Eacmet Exam every year on behalf of Telangana State Council Of Higher Education.
    TS Eamcet Results 2018
  • Anonymous Apr 08, 2018
    The Tamil Nadu state board of secondary education is responsible for conducting the SSLC and HSC exams in the state of Tamil Nadu.The procedure for the downloading of the result of SSLC and HSC examinations are shown in the article.
    dge2.tn.nic.in
    www.dge2.tn.nic.in
  • whatsapppc
    whatsapppc Jun 24, 2018
    Download WhatsApp for. Mac or whatsapp for pc. WhatsApp must be installed on your phone. By clicking the Download button, you agree to our Terms & Privacy ...
  • Rahul Singh
    Rahul Singh Jul 13, 2018
    I genuinely get new ideas and thoughts that help me a lot in my personal work as we
    download audacity free
    President:
On a calc that's work properly, in the 'y=' screen, none of the 'Plot#' things are highlighted. try pressing 'y=', and if you have a 'Plot#" in a black box, go up to it and press enter to un-highlight it.
either it will work as soon as you press 'graph',or you have another problem
Posted on Oct 19, 2008
TI-84 help and support
  • scroll all the way down to APPENDIX B
  • THIS FIXED MY PROBLEM!
trying to graph a function? ERR: INVALID DIM ?
TURN STAT PLOT OFF by [2nd] + [y=] (STAT PLOT)
[4] or scrolling to option 4:STAT PLOT OFF
after I did this the function's graph popped up!!! (if yours does not, try to graph your equation again. DID IT WORK? if not, refer to the link above, appendix B to get help!
Posted on Oct 11, 2008
    Problem Solver:
  • 9 Answers
Go into stat plots and turn off each stat plot individually, trying to select the 4 option will not work, turn off each one individually, worked for me.
Posted on Sep 20, 2009
  • candichamber Jun 29, 2011
    WOW...quick fix that actually worked!!!! Thank you so much from an "old" mom trying to help a "young" son through Algebra II.
Go to stat plot (2nd y=) and make sure all the plots are off. This will allow you to graph again. Hope it helps
Posted on Jan 12, 2009
I thought it didnt work at first but then I pressed enter two times until it said done. It worked! Thank you.!!!
Posted on Sep 15, 2008
These suggestions got me in the ball park, but, where I failed was I had change the setting in zoom. Once I changes it back I was able to set the ymin to 0 or less. I had changed the zoom to #9zoomstat, changing it back to #6 zstandard solved my problem. Good Luck all
Posted on Dec 14, 2009
Invalid dim how do i get rid of that
Posted on Oct 15, 2008
This means you have an invalid command in your "stat plot" screen, even though you want to plot a normal graph. Go to your stat plot screen, and select option 4 (PlotsOff), Press Enter, and try to plot a normal graph again.
Posted on Feb 14, 2007
    New Friend:
"Invalid Dim"
This message has several possible causes.
  • If you get this when making some kind of plot, you probably forgot that you have one of Plot1 Plot2 Plot3 turned on, and it refers to two lists that don't have the same length. The cure is to press [Y=] and turn off the unwanted plot.
  • If you're actually doing something that needs lists, such as a regression, but your lists don't have the same length, you get this message. Press [STAT] [1] and check your lists.
  • You also get this message when you give the TI-83 a list or matrix where it expected a variable or number, or vice versa. For instance, on the STAT PLOT screen, you may mean to press [2nd] [L1] but if you miss the [2nd] you actually type a Y. In the same way you might type a Z where you intend to type L2.
  • Karl Wein offers another possibility. You can create a list called L1, but that is not the same as the predefined list called L1 (note the small-capital L), and of course similarly for lists 2 through 6. If you accidentally delete a predefined list from the editor, make sure to bring it back with the SetUpEditor command.
In general, when you see this message you need to check carefully through what you've done to make sure that you used lists where you were supposed to, and nowhere else.
Posted on Jan 10, 2011
  • guest1849 Jan 10, 2011
    I had the same problem, and just make sure your (y=) "Plot 1" isn't highlighted.
  • Anonymous May 27, 2019
    i think you should visithttps://khophanmem24h.com to find more
The suggested step here did not work form me. It did steer me in the right direction. I went to Stats Plot and to the first area and turned it off. Then I could graph my solution.
Posted on Mar 01, 2007
  • guest1996 Jan 04, 2011
    I Owe you one man! Thank You! Where ever you got that from, I really appriciate that!
  • Click Ngon
    Click Ngon Jun 07, 2019
    Find out more information at :https://clickngon.com/
Whenever I try to graph an equation, I get an message that says error INVALID DIM.
Posted on Oct 08, 2008
I LOVE YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
u are the best
marry me in the wedding of the century!!!
Posted on Sep 07, 2008
Do what he said, if you try to graph something with points than the calc will look forthe pionts even if there are none, thats were invaid dim comes from
Posted on Sep 18, 2007
You might want to check your stat plots and correct the lists used in them. The "INVALID DIM" will show up if you've configured the lists in the stat plots incorrectly. Remedying this is easy; just fix the lists used in your stat plot.
Example: If I had data in lists 1 and 2 but configured my stat plot so that it will use lists 1 and 3, I would receive this error.
Posted on Mar 13, 2009
    New Friend:
    Habit-Forming:
    New Friend:
  • 13 Answers
Thanks for posting a detailed guide on this. This is really helpful. SB Game Hacker Apk Download
Posted on Dec 14, 2017
    New Friend:
I am getting an invalid dim error on sinreg data.... I checked my plot and they are off so when I checked stat edit I noticed I had nothing on there. What exactly am I supposed to plug in there. I entered random numbers and finally got data on sinreg but the data is wrong. So I really need to understand what exactly goes on stats? my graph 7sin(pi/6(x-4))+56...
Please help!!!!!!!!!!!!
Posted on Mar 08, 2014
I have to TI-84. Everytime I try to use the Solver Function an ERR: Archived message comes up.
Posted on Apr 08, 2010
It works for me if you just put in a poin.. 'stat' 'edit' and put a number that isnt on the graph.. unless u want it on the graph. Hop this helped : /
Posted on Mar 03, 2010
I had the same problem and was losing my mind trying to figure out this issue. suggestion worked like a charm. thanks alot
Posted on Sep 29, 2008
Men, u saved my math life
Posted on Sep 09, 2008
Nope
Posted on Sep 02, 2008
You rock! It worked.. thanks.
Posted on Aug 18, 2008
Do what solution 2 sais, it worked for me.
Posted on May 27, 2008
Than
Posted on May 20, 2008
Great thanks
you saved me a whole buncha time on trying to figure it out
Posted on Dec 11, 2007
Worked like a charm!
Posted on Feb 15, 2008
It worked
Posted on Apr 14, 2007
SOURCE:
So on my graphing calculator i put my equation x^3-x^2-10x-8. then i hit graph and it says err:invalid DIM.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd then stat plot, and then select 4:PlotsOff. By the way it is easy to graphing function y=x^3-x^2-10x-8.
See captured images: full graph and detail of the left side max
As you can see this function have zero values in the points -2, -1 and 4
Mar 04, 2012 | Texas Instruments TI-84 Plus Silver...
Error message invalid dimensions
y , and then select 4:PlotsOff.
Jan 19, 2012 | Texas Instruments TI-84 Plus Silver...
When attempting to solve graphing equations GETTING graphing error says INVALID DIM
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If this doesn't do it, please reply to this post and give a sample equation that causes this error.
Sep 09, 2011 | Texas Instruments TI-83 Plus Calculator
My TI-84 Plus Silver Edition Graphing Calculator continues to read "ERR: INVALID DIM" whenever I attempt to graph equations.
Dec 04, 2010 | Texas Instruments TI-83 Plus Calculator
Invalid dim, i have been graphing equations and all of a sudden it pops up with that error message
If that doesn't do it, please reply to this post specifying the equation(s) you're trying to graph.
Nov 03, 2010 | Texas Instruments TI-84 Plus Silver...
Every time I go to graph any equation, I get an error: invalid dim message. How do I fix it?
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" (the F1 key) and then select 4:PlotsOff.
Oct 17, 2010 | Texas Instruments TI-84 Plus Calculator
TI-83 Plus Calculator: I am trying to graph an equation and I get the "ER...
If the message appears when you try to graph functions deactivate the statistical plots. To do so:
Press [2nd][Y=] to access (STAT PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your problem. Post a comment to this thread if you still have trouble graphing.
If the message appears in another context, it sure would help knowing the context of the error.
May 07, 2010 | Texas Instruments TI-83 Plus Calculator
Whenever i press the graph button on my ti-83plus i get an error message....ERR:INVALID DIM
Jan 13, 2010 | Texas Instruments Office Equipment &...
ERR: INVALID DIM (That's the error message I receive every time I try to graph an equation)
[2nd][MEM][7:Reset][1:All ram][2:Reset] [ENTER]. Screen shows RAM cleared. Clear the screen and use [Y=] to enter the functions you want to graph.
Hope it helps.
Sep 27, 2009 | Texas Instruments TI-84 Plus Calculator
Error invalid dim
You're trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Apr 11, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
63,125 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Steve Allison
Steve Allison
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
