Hammering Logo
bernard jones Posted on May 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My onan diesel genset won't start after almost running out of fuel stopped it added more fuel now it won't start
Starlight Power
Level 2:
Sergeant:
  • Expert 117 Answers
  • Posted on Sep 27, 2018
Starlight Power
Expert
Level 2:
Sergeant:
Answers
117
Questions
0
Helped
96282
Points
657
After using a diesel generator for a long time, some malfunctions may occur that will cause the generator fail to start. What can you do when it happens?
If diesel generators fail to start, you can analyze the causes from fuel system failure, electric starting system failure, insufficient compression pressure in the cylinder and the low ambient temperature and other factors.
Maybe the following article could be helpful.
https://www.dieselgeneratortech.com/diesel-generators/why-diesel-generator-fail-to-start.html
Anonymous
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 88 Answers
  • Posted on May 28, 2012
Anonymous
Expert
Level 2:
New Friend:
Night Owl:
Answers
88
Questions
0
Helped
21403
Points
222
Could be vapor locked. Prime the line and try again.
5 Related Answers
Anonymous
  • 508 Answers
  • Posted on Jul 02, 2009
SOURCE: 4000 onan will start and run 5 to 10 minutes and
check oil sensor and oil level check tank for sediment and lines and crb for sediment also coil maybe going bad!!! :)
Anonymous
  • 26 Answers
  • Posted on Aug 29, 2009
SOURCE: onan genset generator in rv is running but no
on your generator ther is a reset if thats not it check for fuses if still no then u neda check the wires in the pluges if no then ur generator it self needs re bilt
Fred Yearian
  • 5603 Answers
  • Posted on Sep 05, 2009
SOURCE: Onan Marquis Indiana 5000 generator
You MAY have blown the rotating diodes on the rotor.
This would require servicing.
Anonymous
  • 9 Answers
  • Posted on Feb 01, 2010
SOURCE: Onan Generator stopped working in motorhome
Yes it wil not let you run your motorhome out of fuel they set it up that way so you dont strand yourself you may have a air bubble in the fuel line to the generator try blowing air generator fule line back into the tank
kel1guy2002
Kelly
  • 3740 Answers
  • Posted on Mar 09, 2010
SOURCE: onan generator emerald III genset. I push the
Here are the most common reasons for your condition.
CHECK IF ENGINE KEEPS RUNNING The most common complaint is that the engine starts but will not keep running when the START switch is released. This happens because the control board will not allow the engine to continue running if the generator is not producing voltage or if the oil pressure signal is not present. See CONDITIONS REQUIRED TO KEEP RUNNING on the Troubleshooting Chart for your model. If the engine will not keep running, do the following:
A1. Generator AC Output Check the generator AC output voltage as soon as the engine starts. Models showing "B1-B2 Volts" or "L1 AC Volts" under CONDITIONS REQUIRED TO KEEP RUNNING need this AC voltage to keep running. Read between the points shown on the Troubleshooting Chart. If the AC voltage readings are good, proceed to "B" below.
A2. Field Flash If there is no AC, check for 10-12 VDC at the FIELD FLASH pin of the control board during cranking. If the field flash voltage is not present, the control board is defective. If the field flash voltage is present, the wiring or regulator may be defective. To eliminate the wiring, check continuity between the FIELD FLASH pin of the control board and pin 7 of the regulator. If the continuity is good, either the regulator or the field circuit (rotor and brushes) may be the problem.
A3 Field Circuit Check the field circuit by unplugging the regulator and measuring the resistance between pins 9 and 10 of the regulator’s mating plug. This reading should be 22 to 28 ohms. If this reading is too high, check the brushes and/or clean the slip rings (use the Slick Stick, or a similar tool). If this reading is too low, there may be a short in the rotor. Also, check the resistance from pins 9 and 10 to ground. This reading should be very high or infinity. If not, there is likely a ground in the rotor. If these readings are all good, the regulator is likely defective.
A4 External Excitation To confirm that the regulator is defective, turn off the generator’s AC circuit breaker(s), reconnect the regulator and apply 12 volts through a diode to pin 9 of the regulator plug (see illustration) while attempting to start the engine. CAUTION: DO NOT attempt this without the diode. If you do, there will be fireworks! Remove the 12 volts within 1-2 seconds after the engine starts. If the genset now continues to run and produces normal AC voltage, the generator is OK and the regulator is defective. If the genset does not continue to run but produces about 40% of normal AC voltage, again the generator is OK and the regulator is defective. If no AC voltage is produced, the generator may have a problem that is beyond the scope of this guide. Re-check all wiring for security and signs of damage. It may be necessary to take the unit to a qualified repair shop.
B. Check the oil pressure switch as soon as the engine starts. Models showing "LOP to GND" under CONDITIONS REQUIRED TO KEEP RUNNING need the oil pressure switch to be closed to ground when running. If the voltage on the LOL/LOP SW pin of the control does not go to near zero, the switch is not closing. These switches sometimes stick open if the generator has not been used or exercised often enough. Multiple start/stop cycles and/or tapping on the oil pressure switch will sometimes fix it. It may be necessary to temporarily jumper the switch to ground to keep the engine running. This can be done at the switch or at the OIL LOL/LOP SW pin on the control board. Models showing "LOP Open" under CONDITIONS REQUIRED TO KEEP RUNNING have electronic governors and require the low oil pressure switch to be closed at starting but open during running. When the switch opens, the governor module places a ground on the oil pressure input of the control board (P1-5). It is OK to temporarily ground P1-5 on this model to keep the engine running. NOTE: See chart for oil pressure and oil level switch locations.
C. If there is AC voltage present on B1-B2 or L1 AC, as applicable, and the correct oil pressure/level signal is present at the OIL LOL/LOP SW input of the control board, and the engine will not keep running, the control board is defective.
This should help you get it going.
Kelly
Onan generator fuel pump
Did you change the pump with the correct Onan pump, these are special low pressure pumps, and automotive pump will not work and can cause dangerous flooding and carb issues.
8kw onan genset wont keep running whrn it tries to take on the load, will run forever if i kick the breaker switch to off.
What is the Spec number?
Also can you read a fault code on the start switch?
Do you know how to read the codes and post? if not let me know
I have a Onan 7000 genset in my rv It starts and
Either you have a kill wire ( if I remember it is the brown wire) that is disconnected on one end or the other Or your in coach switch is bad.
Check the switch this way
Remove the switch from the dash/ mounting surface unplug the brown wire - start the genset - ground the brown wire - it should kill the motor
If it kills the motor your switch is bad
2helpful
Onan Generator stopped working in motorhome because the gas got too low. I blew out the front fuel filter,changed oil and filter, air filter, one spark plug and now it won't start. Is there a fuel shut...
1helpful
2answers
I have a 6500 lp onan marquis generator in my rv. It starts then stops after 15 seconds or so. I did a code check on it using the manual and it read code 47. Controller not reading generator running. Any...
ONANS ARE PRETTY QUIRKY AS IT IS NOT CONSUMER FRIENDLY. THE GENSET IS DESIGNED FOR ROUTINE AND SIMPLE MAINTENANCE PERFORMED BY THE OWNER, AFTER THAT, U WILL NEED TO TAKE IT TO THE NEAREST DEALER OR CUMMINS DIESEL REPAIR SHOP.
3answers
Can u esplain about trouble shooting in diesel generator
my 500 kva diesel generetors dosnt work since mornning its workes after 4 houres when the weather changed
I have an onan 2800 gen that will not charge
If the govenor didn't work that means that you placed the linkage on the carberator the wrong way. This will cause the genset to overspeed and possibly stop the genset from creating voltage. If the genset does not create voltage then you won't have a charger. Fix the linkage first by looking to make sure that the throttle plate is closed before starting genset. Once you start the genset check for voltage.
Top Hammering Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Hammering Expert? Answer questions, earn points and help others
