The Fuser Magnetic High Current Assy. is bad not the fuser but the section it plugs into. located below the control panel behind a cover.
have a tech come out. Try this one time if the code comes back do above do above if do it again the fuser can catch on fire that will ruin a perfectly good day
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
