Guys, I know where Instructions are. On the lock its called "Future Feature". In the Manual its called "Not a working switch". But the Question is what does it (4th switch or slider) do?Guys, I know where Instructions are. On the lock its called "Future Feature". In the Manual its called "Not a working switch". But the Question is what does it (4th switch or slider) do?
I would guess the lock is potentially upgradeable for that lever to has a feature programmed to it in the future.I would guess the lock is potentially upgradeable for that lever to has a feature programmed to it in the future.
You can't post conmments that contain an email address.
Your lock is under one year warranty, with a lifetime warranty if the problem is mechanical or the finish. Here is a link to the website warranty information, and from there you can contact them for technical and warranty assistance:
My lock did not have jumpers, but adjusts itself automatically... You have to hold the lock button in (on the exterior side) while you insert the battery pack - the deadbolt will cycle in and out, then beep a couple times. You'll be holding button for maybe 10 seconds. I have to say while this step is included in the instructions in a big red box, it says nothing about why or what its doing, so I imagine many people miss this...
I had the same question as my son installed the lock. Instructions should be printed on the cover you remove (inside the house). They need to make removing that cover MUCH easier, I'm always afraid I'll break it. Anyway, you press the button once for the first number. To enter a "guest" code, press the button twice then enter the 2nd code in the keypad and press the lock button. Now try both main # and guest #, both should open ttthe lock.
1) Remove back cover (instructions usually are stuck on the inside of the back plate cover .. if not continue next ... 2) Make sure all batteries are fully secured. 3) Press the square Reprogram button 4) Press the keypads of your code. If you do not hear any sound when pressing the buttons, then it means your batteries are not fully secured. 5) After entering your code, press the middle keypad (lock) once. 6) To double check things are working right, then press the keypad buttons again and then when you see the deadbolt is unlocked, then press the middle keypad (lock) again to ensure the deadbolt comes out to lock.
Recommend periodic lubrication of the deadbolt lock for less strain on the batteries ,,, and lubricate the key lock occasionally as well.
I would love to know the answer to your question also!
