Anonymous Posted on May 20, 2012
Konica minolta bizhub 600 error code 2401 - Konica Minolta Office Equipment & Supplies
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Nov 18, 2015
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913671
Points
11960
The erase lamp (EL) is unconnected, was some recently working on the image unit? If so they for got to connect a small connector that provides power to the Erase lamp. OR the lamp is burned out, remove the image unit remove assy. above the drum do not touch the drum. pull up from both end at the rear should be to connectors are they connected? Erase lamp is on that assy. LEDS array along the axis.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5 Related Answers
Anonymous
  • 210 Answers
  • Posted on Jul 09, 2009
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Anonymous
  • Posted on Nov 19, 2007
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
steven brickhouse
  • 19 Answers
  • Posted on Apr 16, 2008
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
firecontrol7
Norman Weimar
  • 7035 Answers
  • Posted on Jul 25, 2009
SOURCE: KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Anonymous
  • 44 Answers
  • Posted on Nov 29, 2009
SOURCE: How do you do a hard reset on a Konica Minolta BH 600?
To recover/change the Administrator password perform the following;
1. Enter the Service mode.
2. Press STOP-0-CLEAR to enter the Enhanced security mode.
3. Enter Administrator Password setting, and enter new Password.
Konica Minolta BH 601 error code 2401
A search using https://www.google.com suggests the following:
  • Code: C-2401
  • Description:The erase lamp (EL) is unconnected.
  • Causes:Erase lamp (EL)
https://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20601&code=C-2401
Web site above includes a link to a service manual.
Konica Minolta Bizhub 600 Error c2401
There was a bulletin or a solution about the sensor wiring in trays 3 and 4 damaged by causing this problem.
The wiring for the sensor in the bottom of tray 3 and 4 can be damaged by the large metal plate that lifts the paper can damage the wiring to the "No Paper" sensors.
Solution:
Subject:
C-2401 at power up. C-2803 may also be indicated.
Description:
C-2401 at power up.
Solution:
PROBABLE CAUSES:
1. C-2401 normally indicates a failed erase lamp, although it is caused, in this case, by a bind in the drum carriage.
Remove and inspect the drum carriage assembly. Run the Toner Cartridge Set mode as well as the Developing unit/Drum.
2. Open ICP6 on the PRCB.
Check for broken or shorted wires in Tray 3 area and repair as necessary. Replace the PRCB (p/n 57AA -902 1J). After replacing the PRCB, go to the Service Mode and set softswitch 32, bit 1 to "0" (OFF). Then re-flash the firmware and, after restarting the machine, set softswitch 32, bit 1 to "1" (ON).
1helpful
2answers
I have trouble code c1139 on konica minolta
There is a fault on the shutter system. The fault will keep returning until you fix the fault.
I have a konica minolta, bizhub 750 that is showing an error massage 'c2401. can someone help?
Thread Bizhub 750 error code 2401
Maybe the link above will help. I found it by a google search, and unfortunately I am not familiar with that model.
How to reset error code 3505 in konica minolta bizhub 600
When you reinstalled the upper and lower fused rollers mite have flipped the sensor so it's not riding on the fuser roller
Codigo 2401 bizhub 600
The erase lamp (EL) is unconnected. Did some one recently replace something in the image unit. There are two small connectors that need to be connected. when the Charge Corona Assy.is installed above the drum that assy houses the Erase lamp.
2answers
Error code c6708
Please send me konica minolta bizhub 600 full service manual and help us this code c6708 still and my next machine bizhub 750 still warming up why problem this machine please help and send me your email address.
i want to talk to you continuous
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
