Power off the machine. Now hold down the 2 and the 5 and power on. Mode 25 screen appears. touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". close out to original screen and power off the machine. wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
I would recommended you get a konicaminolta tech to that it not simple in will require developer, knowing the service mode 36. Clearing counters in mode 25. Try a web site that sell the old Konica Minolta service manual. follow step by step.
Sir/Mam either the code is wrong or the model is wrong. The code is for a Minolta or some konicaminolta machines the model you list do you mean Di5510 which is a Konica machine that use Konica codes like SC35-03. Also the machine problem is listed under Bizhub 250 which I could not fine the code for either.
