I NEED THE COMPLETE NECK, MOUNT, AND STAND FOR THE SONY BRAVIA KDL60EX700 IF ANYONE KNOWS WHERE I CAN FIND ONE PLEASE EMAIL ME AT [email protected]
Try this WEB site.
http://www.nextag.com/sony-tv-stands/compare-html
SOURCE: sony Bravia KDL-32s2000 down from wall mount and can't find stand
Yes, Sony Parts has them available:
800-488-7669
The stand is $107.59, and requires four screws to attach to the TV. They're $2.25. (quite the bargain!)
The model number of the stand is X21033652.
Please rate my answer if it solved your problem.
SOURCE: replacement table top stand for sony bravia 32
OK, Following is part number of Stand of KDL-32S3000 TV
A-1259-944-A STAND (M_WS) ASSEMBLY (KDL-26S3000/32S3000 ONLY)
It is available in Part Store.
Thanks.
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
SOURCE: Sony Bravia 40" LCD TV Stand
There is a slotted area on the bottom of the unit and the bracket on the stand slides over top of it. There should have been four screws that came with the packaging that fit in the four locations in the lower center of the cabinet back that secures the unit to the Stand.
I hope this helps,
Skyassoc
SOURCE: how do I remove the stand of the Sony Bravia XBR
you have to lay the tv on it's front on something to protect it from being damaged.on the back you'll see where the base joins the bottom of the display, this needs to be unscrewed and a wall bracket screwed in instead.
