Dear Linno,
I just wanna know, whether you found a solution for your problem with HP ink cartridges. I have the same problem with my C6180. If you know the solution, please help me...
Thanks,
Balazs Hary
email: [email protected]
SOURCE: HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers
i hope this helps you out
richard from chicago
i just noticed you have the wrong cartage
you need hp 57 color
that will make all the difference :-)
HP Officejet 5500 series
All-in-One model
Black cartridge
Color cartridge
HP Officejet 5505
HP 56
HP 57
HP Officejet 5508
HP 56
HP 57
HP Officejet 5515
HP 56
HP 57
HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v
HP 56
HP 57
HP Officejet 5600 series
Replacing the print cartridges
Aligning the print cartridges
The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
SOURCE: Use HP 363 cartridges instead of 177 for my Photosmart C7183
Let me inform you that printer would be set as per the zone and here is the information regarding the cartridge details.
Zone 1
Zone 2
Zone 3
Zone 4
02
363
177
801
Regards,
Sagarjd
SOURCE: HP PHOTOSMART C4280 PRINTER WONT READ INK CARTRIDGE.
The cartridge is not seated properly and/or the contacts are dirty. Use a cotton swab with rubbing alcohol and gently clean both the copper contacts on the cartridge and inside the cartridge socket. Allow several minutes to dry and then try again.
Phone HP. After about a month hanging on, on their premium rate number, you'll finally be put through to someone who doesn't understand the problem. Then, after your beard has grown another inch or two, if you're lucky, you'll actually get someone who understands the problem. Some birthday's later, you'll be connected to a technician who can talk you through a simple number of keystrokes to re-configure the printer.
Reckon this cost me 30 UK pounds - seriously - I had to call five times but eventually it was done.
SOURCE: Vivera 363 cartridges will not work in HK sourced C6180
Here is some great printer solution by Some FIXYA EXPERT. Get any kinds of printer solution from bellow.
akddij6
