Err message on Skyhawk AT
SOURCE: CITIZEN ECO-DRIVE SKYHAWK WATCH not working
If this watch is several year old, it could be that the power cell is defective, and won't hold a charge. I have been also told by a Citizen Tech, that they will sometimes "hangup" or lock up, and may just need a quick jolt. This doesn't happen often, but Citizen has the equipment to test and supply this jolt to sort of kick start the movement again. They would also replace the battery while it was open. You can sometimes place it into direct sunlight for 15-30 minutes, but no longer...unless you want to melt the insides...lol.
Most Geniune Citizens have a five year warranty. Keep that mind too. Thanks.
SOURCE: I cannot set the date on my Citizen SkyHawk Eco-Drive
The watch will automatically set the time and date when it is in receive mode (Mode hand is on CAL, TME, RXS) Pull crown out 1 click, turn crown to put mode hand in the ORANGE zone. push crown in. Set on stable surface with the 9:00 position facing the direction of the atomic clock signal. Push and hold lower button for 2 seconds till it beeps. it will enter RECEIVE mode and in 2 -15 minutes it will (if there is signal) update time and date automatically. While in RX mode the lcd windows will flash between RC & RX, the second hand should show signal level between 1 & 3 hr positions.
Do NOT move the watch until it has resumed the one second sweep motion and made a beep.
SOURCE: setting time on my citizen eco drive skyhawk model jr3090-58l
Go to this site and choose interactive settings for your watch:
http://www.citizenwatch.com/COA/English/find.asp
Do not forget to rate, please.
SOURCE: i have a citizen eco
Go to Citizens web site and find your model. You can down load the instruction manual there.
SOURCE: Citizen Skyhawk Eco-Drive JR3090-58L instruction
http://www.citizenwatches.com.au/instruction-manuals
You will need the calibre number on the back of the watch but try this citizen site.
