Our ovens heating element failed. We replaced it with a new element and the oven heats up. However in looking at the element while it is on only 75% turns red/glows. The entire part of the element running along the back of the oven does not glow. Is this normal?
SOURCE: bottom oven element sparked then quit working
The element sometimes will continue to arc inside after it burns out. It's 220 volts jumping across the break.
SOURCE: replace the upper heating element
hi E mail me model no can proberly sort it. [email protected]
SOURCE: oven doesn't heat up
Hi, Even though your igniter is glowing it's bad..A igniter should glow brillient yellow for it to be able to light the gas...basically whats happening in your case is although the igniter is drawing the correct amps to open the gas valve it is not getting hot enough quick enough to light it..change the igniter and you should be good to go. Good Luck!!! Mike
SOURCE: RATIONAL COMBI OVEN ELEMENT GLOWING RED -IS THIS NORMAL?
your oven is electric yeah? the hot air element shouldnt be glowing like that, it glows with the door open? the oven has a over temp stat so if the oven got too hot then it would trip out, if it does then the solid state relays will have to be changed, but if it carries on as normal then shouldnt worry
SOURCE: The oven heating element seems
If you can see the element heating up, but the fan is not working, then you need to replace the fan motor assy, if you do not, then the element is in danger of burning out.
