Lucien Piccard 26024 Wrist Watch Logo
A
Anonymous Posted on May 02, 2012
Trying to remove a link on a ceramic dkny watche
1 Related Answer
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Feb 25, 2011
SOURCE: how do i remove links from a ceramic lucien
Browse through my Tips and Tricks. There you will find how to add or remove links.
1helpful
I am trying to get two replacement links for my DKNY watch, any ideas? the old ones were shattered when dropped
I sustect that these are ceramic links. Your best bet would be to set up a search on eBay - you might get lucky and get a non-worker cheap that has links that you could use.
2answers
How do you remove links from my watch band DKNY?
Instructions
    • 1 Determine the amount of links that need to be removed for the watch to fit on your arm correctly.
    • 2 Find the tiny holes on each link. Most DKNY link wristwatches, such as the 3107 model, have holes at the links near the clasp.
    • 3 Using the screwdriver, gently push the pin holding the link bar on the first link you want to remove. The link bar should come out on the other side.
    • 4 Take the pliers and completely remove the link bar from the band. The link band will still be attached to the clasp. Remove the link with the pliers. Repeat Steps 1 through 4 for each additional link you want to remove.
    • 5 Gather the watch band and and bring the two sides back together. Join the link bar and the clasp together and, using the screwdriver, press the link bar back into the hole completely.
How to Take the Links off DKNY Watch eHow
Aug 27, 2014 • Watches
Broken ceramic link
David only a professional can fix this or replace it.
2helpful
Cam i get spare links for dkny clear links watch
yes Dkny will give you free links for your watch if you need them . DKNY watches are made by fossil watch company, you can contact them at this telephone number# 1-800-449-3056 to have watch links sent to you.
Oct 14, 2010 • Watches
2helpful
I-have-a-ny3715-watch-with-a-stone-missing.it-was-bought-in-new-york-last-november-i-have-the-reciept.i-have-tried-local-jewelers-but-they-cannot-fix-it.how-do-i-get-it-repaired-
Your best bet is to contact DKNY to see if they can replace it for you. Other then that, I would try a local jeweler. Here is a link for the DKNY service center: http://www.dkny.com/contact/ Good luck!!
4helpful
How do you remove the links form the DKNY 4351ladies watch?
there are pins in the watch the pins have one large end and one small end you want to push the small side into the watch, make sure the pin can come out the other side you can use a thumb tack usually.
The link on my dkny watch has broken and I would like it repaired where can I send it
Hi
Thanks for using FixYa. You can get it repired from an authorised DKNY service center or can also get it done from these tech.s--
Watches Repair Link
Please do rate the solution and revert for further assistance.
Thanks
Rylee
2helpful
Watch band sizing
OK, I make an attempt:
I saw on other pictures on the web that the links have small holes at the side. There should be some links with arrows r another marking. These are usually the links that can be removed to shorten the strap.
If there is a small arrow on the link, it means that you can push out the pin inside the hole in the direction of the arrow. Then the link can be detached.
You can push it out with a blunt sewing needle (break off the tip).
Remove links on both sides of the watch when resizing it.
Hope that helps.
Critter
8helpful
2answers
Dkny watch- repair, need extra links
I suggest calling DKNY customer service @ 1-800-231-0884 This is their return or repair department they should be able to help with links for your watch.
Mar 09, 2008 • Watches
Top Lucien Piccard Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you a Lucien Piccard Watch Expert? Answer questions, earn points and help others
