Televison & Video Logo
Posted on Apr 20, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba D-VR610KU recorded disc won't play in my Daewoo DVD5800
I have recorded and finalized two Verbatim DVD-R discs on my new Toshiba DVR610KU . These were home movies which I transferred from an 8mm camcorder to DVD through two jacks on the front of the unit. They playback fine on the Toshiba recorder, but will not playback on my Daewoo DVD5800 player. It will show occasional "freeze frames" of video and audio. I tried changing my region code from US=1 to All=9 on the Daewoo player, but it didn't help. The player is five years old, but I was told the DVD-R discs would work on older players.
Toshiba customer assistance was unable to help me.
solver2010
Level 3:
  • Master 923 Answers
  • Posted on Apr 20, 2017
solver2010
Master
Level 3:
Answers
923
Questions
0
Helped
192853
Points
2907
What are the compatible types of DVD's that the Daewoo DVD5800 player is supposed to play? Is DVD-R among the compatible types? Try playing the new recordings on a computer that has a DVD drive, or a friend's computer.
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Mar 23, 2007
SOURCE: dvd "unknown disc" message coming up
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
Michael Borelli
  • 979 Answers
  • Posted on Mar 17, 2008
SOURCE: ILO DVDR05 recorded DVD's freeze
Burn your DVDs at tow positions slower than what the system and discs say. It sounds as if there is a huge amount of error being introduced during the write process. Unfortunately, the old discs can only be recovered with an external program like Zero Assumption Recovery or the like....accordianman
Anonymous
  • Posted on Dec 15, 2008
SOURCE: unable to "dub" my 8mm tapes onto DVD-R using my Sylvania DV90VE
From comments posted on the Internet by other Sylvania users with a similar problem, I  learned that I had to use a 4X DVD-R (the ones I had been trying to record on were 16X). And I found that Office Depot sells the sometimes hard-to-find 4X format, so that's where I'm headed right after lunch.  Thanks.
Thomas F. Schneider
  • 2715 Answers
  • Posted on Jan 11, 2009
SOURCE: FINALIZE RECORDED DVD
Here is the sharp support website. You will need the model number and the above may not be it.
http://www.sharpusa.com/products/support/options/1,2310,,00.html?model_num=+250+&s_func_disp_id=13&x=45&y=7
Anonymous
  • 23 Answers
  • Posted on Apr 15, 2009
SOURCE: Recorded DVD will not play in another player
try playing on computer. if ok copy on hard drive and burn it. if it wont work on your computer. there was an error in the making of the disk..
1helpful
All of my recorded discs are DVD-R. Will the Toshiba DR420 play DVD-R discs?
Yes,it well play on Toshiba and all other brands of the DVD Recorders.If your DVD- R discs do not have any finalizing codes in the orignal recording device u use to record it.
1helpful
4answers
Anything I have recorded onto DVD from TV wont play on any other machines. It will only play on this machine I recorded on. It is the same make and model mentioned here.
If you're not using DVD+RW blanks (VERBATIM work fine), then try them. DVD-RW blanks will not play on any machine but the one that recorded the disk (according to the manual.)
2helpful
2answers
Disc initialization Toshiba D-R250SB recorder
can i suggest you record vhs tapes on maxell dvd-r or tdk dvd-r (if you wish to keep them) used the dvd-rw to record those sporting events / movies or specials that you might not be around for....(because any one can accidently erase an dvd-rw).......now that formatting dvd-rw issue. i found that dynex http://www.dynexproducts.com/c-11-storage-media.aspx dvdv-rw works best with toshiba . i record all the ultimate fights erase (format) after i look at and on to next good luck
Finalizing DVD-R fails, rendering Verbatim disc non-readable
You might try finalizing the disc in a PC using IMGBURN or other DVD recorder software. It couldn't hurt...
tom
3helpful
2answers
I have toshiba dvd recorder,the problem is the recorded dvd cannot play with other player. Do I have to return this recorder as it just a week away since i buy it
Make sure you Finalize the disc when you are done recording, otherwise it won't be read on other players or computers. To do this you go to Setup> Disc and choose Finalize. It takes a few minutes per disc, don't turn off the player while it it finalizing. In the same Setup menu you can choose an option to autofinalize the disc when you are done recording, so you do not have to to it manually each time.
9helpful
7answers
Toshiba d-r4su won't finalize
to clear "error 14", press the "display" button on the remote control - this has worked every time my toshiba has an error 14 message
1helpful
2answers
Daewoo DVRS05 Recorded DVD won't play in OTHER DVD players
my suggestion from reading other forums is that these players sometimes have problems finalizing the disc.. you could try making a copy of the disc in a computer to see if this fixes the promlem or maybe media these use dvd+r and has a lot of compatibility issues with dvd players.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
