Does the control panel say replace PC drum? You need to have the Drum/Developer and the Developing unit replaced. Make sure that the counters are cleared before removing the old unit and make sure F8 is run after the new image unit is installed
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
SOURCE: Put in new toner into KonicaMinoltaBizhub200,says exchange toner
Machine is still saying to exchange toner because toner is not feeding into the machine.
to supply the toner always do this,
1-insert the new toner bottle in the toner section and close the cover.
2-Press "Utility/Counter" Button.
3-click on "USER CHOICE" or "USER SETTING"
4-click on "Toner Supply"
5-Toner bottle will start moving and hence the error message will not appear again.
SOURCE: how to fix error c-1183
This code is for a bin/tray raising or lowering failure in the finisher. This can be caused by either the trays not being fully inserted into the finisher or something stropped the bins from raising or lowering. Check the trays and make sure they are as close to the finisher/fully installed as possible. Then turn off then back on the main power switch (NOT the stand by one on the control panel)
You should see the bins raising and lowering into their home position.
