I do not know what part #83242 is. A search of several reliable parts web sources, yielded no positive results. So, I'm guessing this may be a door handle(?). If so, to access the door handle mounting screws on MOST
microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and
work your way slowly around the perimiter of the glass. Most
microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful
microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you need to remove the entire door, simply open it all the way and lift at the hinges. The door will lift off the hinge mounts. You may wish to remove the door for an easier means of working on it. Especially, if the microwave is mounted above your range.
If you have questions, please let me know. If this is not what you are needing assistance with, please post back with the name of the part you are trying to replace. I hope you find this information helpful.
