Toys Logo
Posted on Nov 12, 2008
Disney Talking Woody Doll - String stuck in pulled position
My child pulled the string. The string will not go back in and will not make Woody talk. I cannot see a way to easily get into the white plastic cylinder. Part of which houses the batteries. It is inside Woody's shirt and will not easily come out. The string is sewn into Woody's shirt and vest.
  • 3 more comments
  • Anonymous Jan 01, 2009
    yes my son pulled the string a little hard I think.. and now it will not move either!.....
    is there any way it can be fixed???
  • Rubybay71 Sep 07, 2011
    Hi
    Please can I have schematic of circuit for pull-string Woody.
  • Patrick
    Patrick Jul 04, 2015
    Well I would like you all to know this is July 2015 and the game is still on. The time spent has been in excess of 5 hours to relocate the drive spring - that took 3 hours - then replace the axle and cam. 2 hours later it was in place but when pulled no movement. Loosened it a bit - sound. Tightened it up - no sound. Mid-night gave up.
    Will try again in 2020!
  • miya bhai
    miya bhai Sep 27, 2019
    Thank you so much for this. I was into this issue and tired to tinker around to check https://tracktrace.one/usps/ if its possible but couldnt get it done. Now that i have seen the way you did it, thanks guys
    with
    regards
  • john smith Oct 07, 2019
    hello,
    Thank you so much for sharing this helpful information, it helped me alot
    Thanks and regards.:)
Cooldada
Level 1:
  • Contributor 4 Answers
  • Posted on Dec 26, 2008
Cooldada
Contributor
Level 1:
Answers
Questions
0
Helped
19335
Points
39
A friend of ours gave our son a hand-me-down Woody doll with no string at all. I decided to see if I could fix it...about 4 hours, 1 soldering iron, and the realization that my eyes are failing faster than I thought, I was able to return Woody's voice. I'm sorry I didn't take any pictures, but here's what you'll need to do depending on what you find as you operate.
0. Perform of these steps over some sort of container to be sure that you don't lose any of the small pieces that may be liberated in this operation (particularly a small spring that comes later).
1. Take out the battery pack through his lumbar Velcro. There is a black wire that carries power into Woody's thoracic cavity to a module that houses the electronics.
2. You will have to untie, or otherwise get the string through the hole in Woody's back so you can work on it...I don't know what's at the pull end of the string since the Woody we inherited had no visible string.
3. Cut open the white fabric inside Woody that separates battery pack from the electronics module.
4. Take out the two screws that hold the two halves of the module together. CAREFULLY separate these as there are a couple of wires that run between the half with the electronics and the half with the speaker.
5. If you are lucky, which I was not, all the wires will be intact and you will only have to restring Woody. (Nervous sytem work (i.e. wiring) will require a soldering iron and perhaps the assistance of an additional set of hands...)
6. The string is wrapped around a spindle which is spring loaded on one side (it's the big spring - not the little one). With the spindle side of the module towards you (big spring to the lef), the string *should* come up in front of the spindle, over the top and down through the hole..at least think it should. Again the string was broken in ours and once I opened the module, I couldn't tell which way it was originally.
7. On the right side of the spindle is the mechanism that completes the circuit when the spring is pulled. This includes a small spring, and metal piece that makes intermittent contact when the spindle winds back up after pulled.
So, depending on what you see when you take the module and battery pack out you may find:
0. Oh, of course, replace the batteries just to be safe.
1. The string was just hung up in Woody's back and simply removing the module allowed it to be come free again. Piece of cake.
2. The string was bound up around the spindle in which case you just need to clear it and be sure that it winds up properly when pulled. You may need to rewind the string, in which case you need to lift the right side of the spindle (take care to observe how the spring and metal piece are configured...and DON'T LOSE THE SPRING..it took my 10 year old daughter's eagle eyes 5 minutes to find it after it went shooting off the table)
3. The spring mechanism is somehow stuck. This will require tweezers and some patience to sort out the cause.
4. You may have to replace the string. I found some laying around the house that was close to the small shred that remained in our Woody.
5. Finally, I actually had to solder down 3 wires to get the circuit to work. If you're in this predicament, let me know and I will draw a picture for you of what goes where.
In the end, I got Woody to talk again, though he tends to speak without being pulled from time to time. But I gotta tell you, the feeling I got when he burst out with, "Howdy partner, my name's Woody!" was about the best feeling I've had in a long time.
Good luck, and let me know if you need any more information.
Shawn
  • 1 more comment
  • Rubybay71 Sep 06, 2011
    I have a loose wire, can you help? I had him all but fixed (pull string problem) but my husband "helped" and pulled a wire out!
  • Jolene Knight
    Jolene Knight Apr 20, 2015
    Hi there, the problem with our woody doll is that the string was pulled to hard and seemed to either disconnected from the spring machism or the spring broke. I'm going to look at it again, but my question was...would know where I could find another spring? I've been thinking maybe from another pull string toy perhaps...but not too sure, thanks a lot
  • Gina erdmann Jul 20, 2019
    Please send wire diagram! One of the white ones connecting the voice box to the circuit board broke off, I know where one end goes but not other side.
My daughter got a woody doll is not saying anything. I have never gotten it to speak. The string works but nothing happens.
Hello, Stephanie -
If your daughter was given the Woody (from Toy Story) talking doll recently, I suggest you contact the person who gave it to her, explain the problem, and ask where he / she purchased it, so you can find out about the warranty on the toy. Reference to warranty information may have been printed on the box the doll came in, but you probably do not have that. :)
If the person who gave your daughter the doll still has the sales receipt, the doll COULD be taken back to the store where it was purchased and returned in exchange for a working one. Or, if the doll was purchased on line, the person who gave your daughter the doll could contact the seller and return it in exchange for a working doll.
I have found information online regarding a broken pull string to activate speech on the doll. See Fixya.com replies here:
http://www.fixya.com/support/t6602305-woody_doll_pull_line
Best wishes.
Apr 27, 2018 • The Toys
1helpful
I need the manual for the baby loves to talk doll
Contact by email a seller of this vintage doll and ask if you can purchase a photocopy of the instructions they are selling with the doll, which would get you a copy, and they could sell the original instructions. (You also could search using ebay.com or www.google.com to see if anyone else has the instructions available.)
http://www.dollysisters14.com/talking-dolls---croner-baby-loves-to-talk.html
Pull string talking vinyl doll
Picture below is a different doll, so don't worry. Open the link above to see the doll itself. (I have no connection to any sellers.)
Apr 21, 2018 • The Toys
Jessie doll string in the pulled position
Sometimes you can get the string cord to release and retract back. Hold the doll firmly and gently pull the string out about an extra two or three millimetres (eighth of an inch) or as much as possible. Keep the string tight for a short while and then allow it to retract slowly. It may take a few attempts, the skill is in pulling the string that little extra distance, holding it for a few moments, then slowly releasing it again.
Dec 30, 2013 • Toys
Need replacement hat for pull string woody
This is the amazing way for the web users connect to get here this latest version of the adding printer windows 10 i hope you see the function to use this online use the USB cable to plug in the system and have the best image of the print. How to Add Wireless or Network Printer in Windows 10
My grandaughter's new jessie doll quit speaking. i don't know if it uses batteries or if the speach comes from a player energized by the pull of the string. is there any way to get the clothes off...
Truthfully, most of the time, you cannot take the clothes off of a Jessie doll. No matter what company, they will always stick to the body, including the boots. Sure, you can take the hat off, but not anything else. If she has stopped speaking, she needs new batteries. THANK YOU!
2answers
My son got the talking woody doll for christmas and he was playing with it last night and it fell off the couch on to my hard wood floors and his face completely split in two pieces. He is devistated! I...
Take it to walmart or whatever store it may have come from and explain the situation. They're normally good with exchanging items without box or receipt if it was a gift. Good luck
Top Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Toy Expert? Answer questions, earn points and help others
