Mitsubishi WS-55809 55" Rear Projection Television Logo
Posted on Nov 12, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TV power will not stay on.
We have a 55 inch Mitsubishi TV WS-55819 Model. TV power will not stay on - green light cuts off after about 2 seconds.
  • Anonymous Dec 13, 2008
    It sounds like I have the same problem. The TV turns on for a few seconds (with the timer light), then shuts off. Can someone tell me what part I need?
    Nicole
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 31, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
473
Points
Mine was the 904 and 905 pico fuses in the power board. $4.00 is what the fuses cost me. I put them in myself and have never worked on a tv before....
Anonymous
Level 2:
Scholar:
  • Expert 93 Answers
  • Posted on Nov 22, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
93
Questions
0
Helped
33391
Points
136
Not worth to fix.Either power supply,sensor or convertion board are too costly for the part.Buy a new TV.
solutiondoct
What does a 2-3 dignostic code on a Mitsubishi 55819 mean?
2blink-then 3 blink---------deflection circuit problem
It is a little misleading but means something in Horizontal or high voltage circuit (covers a lot of area inside the set) is bad.
Going to need a service manual, etc to try to track it down.
Entire chassis for this set can be removed====called a light box.
Mitsubishi WS-55819 TV Wont turn on.
code stands for loss of vertical. I had one of these if you can check pico fuses, check the ones on the main power board the one with the 2 convergence amps if any of them are blown then most likely the convergence amps have shorted out.
1helpful
Mitsubish WS-819 Protective Shutdown. 2 blinks, pause, 2 blinks
Over 95% of the time a 2 - 2 blink code on that model is a convergence output problem. You need to replace both of the convergence output IC's and perhaps the pico fuses feeding them voltage. The pico fuses are F9A04 and F9A05. They are on the same board with the convergence outputs.
Mitsubishi WS-55819 power issue
No, that'll do it. Once you've changed em you'll know right away if somethin isn't right. But take faith and fire that puppy up. If the pix is good you did good. If something is amiss. I'd be happy to walk you through it. My money is on you though.
My tv ws-55819 tv won't turn on it cliks on but it won' syat on
ok when the power is plugged in hold down the menu + device buttens for five sec what is the error code there should be two sets of numbers....
like 1 pause 2 let me know and i'll see what i can do!
Mitsubishi WS-55819 Won't turn on
If F9A04 and F9A05 are open the convergence ICs will need to be replaced as well as the two pico fuses. You will need two STK392-570 Convergence ICs and two 5 amp pico fuses. You ca get the replacement parts at the following link with free installation instructions. heres thelink.
http://servicemanuals.vstore.ca/
LED Blinking
Okay 2 blinks isnt a error code, so your set isnt shutting down due to a protection issue, so I would suspect one of the low voltage regulator transistors or the horizontal output transistor as being defective
2answers
It won't power up
You need the HV splitter. You can leave a email at the following link state your model number and let them know you need a HV splitter. They will respond quickly to your inquirery and they will provide free tech support to explain how to change the part.
Mitsubishi ws 55819
Bad convergence ic and should replace caps also
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
caps:
· http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm · http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
· http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
· http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
