Want to put it on cotton wash red button stuck on spin speed ans there Is a snowflake looking thing on screen top left have tried switching off from main etc can't budge it
SOURCE: Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
SOURCE: Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
SOURCE: BOSCH Maxx washing machine will drain and fill but
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Plug
off the wall first. Remove the front
lower panel, screws underneath. Be
prepared for water, drain out from drain hose.
Check filter for clogging, clean out.
Sometimes when the load is unbalanced & the machine cannot adjust
the load it stops. To avoid this make
sure your wash is mixed with big and small clothes.
If
this does not work remove the rear panel & check belt, should have half
inch ‘give’. Still not good, remove belt,
unscrew 2 bolts that hold the motor, unplug the motor connector, lever the
motor back with a screwdriver. Check the
motor brushes (at terminal end of motor), if they are any shorter than 1 cm
replace brushes.
Try
these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Pl click 'very helpful' for the free help, thnks.
