Zanussi FJS1225W Front Load Washer Logo
lorraine fisher Posted on Nov 08, 2006
E90 Error Code
Keep getting an E90 Error Code, does anyone know what this is?
  • 1 more comment
  • Anonymous Apr 26, 2008
    Can you tell me what E90 means on a Zanussi FJS 1225W washing machine
  • Anonymous Dec 30, 2008
    Error code E90 when trying to operate the Electrolux Washer. What to do?
  • Mosey1 Apr 20, 2009
    E90 error code appears and seems to disable the whole machine. Can leave machine switched off for a while then operates normally again. E90 has shown up on the rinse part of the cycle just when the drum has been filled.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 21, 2006
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6945
Points
13
An E90 fault is a problem relating to the main control module found behind the front facia. it could just be a bad connection on the board connections though
Anonymous
Level 1:
  • Posted on Nov 20, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6945
Points
I am getting an E90 error because I moved my machine to Brazil and the Electric is 220 but 60 Hz. So I am saying there is a power supply problem perhaps.
Can anyone tell me how I can resolve my problem other than sending the machine to my Mum in UK and getting her to do the washing (lol!)
Anonymous
Level 1:
New Friend:
  • Posted on Nov 14, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6945
Points
E90 Means (Program blocked due to error)
A
Anonymous
E20 is problem with water draining - according to the instruction booklet.
E90 error code on fridgidare front load washer
The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection.
https://www.appliancepartspros.com/answers-for-frigidaire-control-electrical-137006000-ap4358809-question-70945.html
What Does Error Code E90 mean on a John Lewis Washing Machine JLWM1202 made by Electrolux
How should anyone know? Go to the web site and find out so you can be guided accordingly.
What does it mean when E90 flashes on my Simpson front loader 7kg washing machine and it's stopped working?
The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer as this will be the only way to know for sure...
2answers
E90 Error,How do I fix or clear the E90 error I am getting on my spa?
What should I do if code E90 appears on - Intex ' Frequently ...
www.intexcorp.nl/faqsup/pub/FaqSupportServlet?action...
Jan 19, 2015 - What should I do if code E90 appears on my air bubble spa control panel? ... If alarm code E90 is displayed on the control panel, it means no ...
Oct 14, 2015 • Pool & Spa
How do you fix error code E90 in my intex spure spa pump?
You have an owners manual I hope, with
the codes & trouble charts
I would say call the pool & spa store & have
someone trouble shoot the problem
Nov 10, 2014 • Pool & Spa
It is flashing E90
The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem, may be a power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed.
Good luck.
2helpful
Machine flashing E90 and not working.
The E90 error code is not a specific code. The error code E90 is just a group error code. It is indicating a communication error between the two boards in your machine. It does not indicate where the problem may be. A power glitch may have caused the E90 error code or a loose connection. One of the control boards could have failed. If it did not clear by unplugging the washer, I recommend a technician come out to properly diagnose your washer.
5helpful
I have a electrolux front loader ewf 1087 that shows the code e90 on start up...i have cleaned the plug that the blue wires go in to & still flashes e90 con soneone help..thanks
3helpful
2answers
PUK Code for Nokia E90
you have entered the pin code wrong 3 times now you are required to enter a puk code to reset the pin code.
imei has noting todo with puk code which is on the sim card which is not related to the phone at all.
The puk code is sim card spesific it comes with the sim card when you get it or you can get it by calling your phone service provider of the sim card to get the puk code.
if you have entered the puk code wrong too many times you will make the sim card useless and you will have to contact your phone service provider for a new sim card, it will probably cost.
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
