Hi. Try : unlock the car ( push open 3 times) open doors from outside ( make sure they unlocked) switch child lock to lock position and back to open. Pull again on the handle after you switch before you close the door. Let me know if it helped.
If your back doors won't open from the inside then the child proof locks maybe turned on. Open the door from the outside and look at the edge of the door near the lock for a small lever or screw setting for the child proof lock. Tun off the child proof lock and then you can open the back door from the inside.
i got peugeot 106 ...! when i waz washing my car by mistake i lock child safety lock....! and i can not open it agein how ever i manage to un lock child key but the door still lock plz help thanks,,,,,( i tryed evre thing)
Child Locks will stop anyone on the inside of the car from opening the door. If the child lock is on then the door can only be opened from the outside of the car. Of course the main door lock must be off just as any door must be unlocked to be opened from the outside.
Now if you do not want the child door lock to be on then you must first open the door from the outside with the main lock open or unlocked. Look at the space that is covered when the door is closed. There you will see the lever that turns the child lock on or off. Simply move it to the off position.
there is a slider switch on the door(between door and frame) that you can lock or unlock the child locks to prevent them from opening the door from inside but still can open door from outside----just slide the lock switch to enable or disable the child lock.
if they are stuck/stiff---you may have to remove the door panel for repair.
Usually they work free with a liitle lubricant(WD-40) to slide easier.
the child safty lock may be on but that wont stop you from opening it from out side,,,, it only stops kiddys from opening it from the in side,,,
i think the lock has broken?
It has nothing to do with the "child lock" It is a know problem in this car, they tend to get caught in lock. Only thing to do, is to take of the panel then the outside handle, and through that hole destroy the plastic covering the lock, a large screwdriver and hammer will do! Then you can release the lock, while you pull the inside release handle. Buy new!
sanyo asw-a85ht washing machine
yes
