Televison & Video Logo
Posted on Nov 09, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My DVD player will only play background sound not voices
My son was playing with the remote the other day and now my spectroniq dvd player will not play voices on most dvds. However background noises play just fine.
  • Anonymous Mar 30, 2014
    I play my DVD player and it's coming only voice not video can anyone know?
Anonymous
Level 3:
  • Master 10,594 Answers
  • Posted on Nov 09, 2008
Anonymous
Master
Level 3:
Answers
10594
Questions
9
Helped
2957441
Points
33084
Go to sound menu of dvd player and select Stereo sound and if surround is enabled, disable it.
You can get help from user manual of dvd player.
2answers
My Denon AVRX3100 works fine with my Dish Network TV. The Panasonic DVD player (attached to either DVD or Blueray inputs) only has partial sound. The movie background music plays but not the voices.
Your denon amp amp does not match and work well
in some players for instance "Samsung" no pictures
and sound via HDMI input. Only replacing players
to another brand such as LG can fix the problem.
When playing any DVD there is no sound when people are talking.
Check the language mode settings on the DVD player.
The language settings may be set different than the DVDs setting. This will cause the voices to dissappear if the DVD does not have a sound track in the language selected on the DVD player.
If I were to guess, make sure it is set to play in ENGLISH. =D
1helpful
Dvd player has no voices, music, backgrond, hooked up to multiple speakers
Check the inter connections. Wire break might be the reason.
My Son down loaded a Movie from his Laptop and played it on the OLIN DVD player The downloaded movie from the USB movie had nod Voice there was sound from background music but no speaking sound now the DVD...
Hi, and yes I would agree with you that there is one channel not getting decoded. The likely problem is a setting in the menu of the dvd player under " AUDIO SETTINGS " . It may take a couple of trials and errors to get it back to where it was before ( just because we aren't sure what the original setting was )I would suggest that you make sure the " DIGITAL OUT " is set to " PCM " versus " LPCM " because this being improperly set can mess up your surround sound. Also there mar be settings for " DOWNMIX " labeled " LT/RT-STEREO and a couple others whose names escape me at the moment. Changing one or more of these will almost assuredly get you back on track. Good luck and thanks for choosing FixYa. I hope this helps, Prodzilla
No English language on DVD 's
Bought a new unit. The old unit was a surround sound system in which the previous owner removed the speakers. I wasn't aware of the problem but found out that it would not allow it to play on Dolby 5.1...It would only play DVD's on channel 2, therefore no english etc. Thanks for your help!!!
3helpful
Sudden problem: voices can't be heard, everything else normal.
If this is on a home made dvd then that is probably where you the problem is.
If you try a proper store bought dvd and that works then you know its the other dvd.
But if a proper store bought dvd give the same errors then it could b a setting or part of the sound replay circuits that have or ore dying
Spectroniq DVD Recorder SDR-205 Disks do not play with proper col
the remote control doesn't work with new batteries
SUPERSONIC SC-29D There is no sound from actor or actress speak, but has back ground sound
Set sound properties to Stereo by going in to menu of dvd player as it seems its set on AC3 or Dolby Surround some thing.
Need further help, let me know.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
