My ti 84 plus silver edition seems to be on a different language setting because i dont understand anything it says. what do i do to change it back to english?
The easiest way to fix this is through the Apps menu. Hit the apps key, then scroll down until you see any language(espanol, Deutsch, etc.). It should give you the option of switching to either that language or restoring to English. I just tried this on a calculator that was set to German. I hit Apps and scrolled down until I recognized the option for Spanish, and it still worked. It let me switch back to English.
Hope this works for you.
Instead of resetting everything, just try going into the apps, then scroll down until you see espanol(spanish) and press enter. then it will come up with Texas Instruments 1:espanol 2:english. then press the number 2 and it will reset the language to english.
Hope this helps,
Muffin Lover
ON, Apps, scroll down until you see English, press enter. There might br several language choices there...Dutch, French, etc...
Even try: 2nd, mem, 7, 1, 2, enter to reset all RAM.
I was able to clear the memory to get back English. I had to follow the numbers on the menu because I can't read the German words on the menu.
key in 2nd MEM
key in 7 for resetting
go right arrow twice to select the third menu (like "ALL" in German)
key in 1 for ALL
This will clear all memory, archive, RAM and apps. I don't know how it got to German, but now I have English back.
Hope this helps you,
Dew
F(x)=x2-6x
my i dont think my calculators in english, but i cant see the word english anywhere......
My calculator is in french and I am not sure how to change it back to english!
Someone has deleted the english app from my calculator. And the mem reset option did not work.
i had the same problem and the above solution worked perfectly, thanks
