SOURCE: lights flashing on indesit WIL123S
Hi, sounds like you need to change the door interlock located where the door catch pushes into.
Take the top off and undo the two screws with a tork screwdriver
and replace.
(Remember to turn off the supply and pull out the plug top)
SOURCE: Indesit WIL143S flashing lights
hi have you unplugged your washing machine for 2 mins then plugged it back in to give the machine a reset..its says it in my WIL 163 MANUAL TO DO IT was wondering if your is the same gl
SOURCE: The door lock flashes constantly - Indesit WIA101
Switch on machine and start its program. While it is running then turn program selector control to TOP position. After a few seconds ALL lights should flash and machine should stop. It ought now to have been reset to normal.
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
SOURCE: indesit WIDL1265 flashing lock, rinse and timer
Hi
Problem possibly caused by blockage in drain pump filter. If you remove the bottom plynth you will find a black screw cap (about 2" diamiter). BEFORE you unscrew you will have to make sure you have plenty of towels and low bowls because all the water from the drum will flood your kittchen if you unscrew!!!
How I do it is that i (with someones help) try and pull the washing machine out . Then i tip it up 45 degrees With someone holding the washing machine I place plenty of towels underneath the washing machine and SLOWLY open the filter.
I bowl will catch a lot of water but it will still be messy.
When all the water has drained pull the filter out completely and you will probably find all sorts of debris there.
If the filter is clean look inside the filter body just in case there is a coin or two there as these will jam the drain pump and stop it from draining.
Hope this helps
aardvark Repairs
