SOURCE: need written instructions on how to reset Ip code Konica bizhub C451
there are two ways you can rea\set the ip address you can press utility counter administrator password is 12345678 the go to network ip address and you can chane it there if you know the ip address you can browse to the machine and log in as administrator and go to network and reset there
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
SOURCE: Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
SOURCE: how do we change the language on the konica minolta bizhub c351
1) Press "Utility-User Setting-Language Selection
2) Go to service mode System 1 - Marketing Area - US
You have to do both
