If you want the table to be generated, you must use the table feature. You can generate a table also after you draw (graph) a function.
Enter a function in the Y= editor, then press GRAPH or SHIFT GRAPH (TABLE). If you press GRAPH, you will see a graph. If you want the table and are not interested in the graph, press SHIFT TABLE.
SOURCE: I think I pushed a
You do not say that you opened the Y= editor and typed in at least one function and THEN pressed Graph. If you do not enter a function, all you will get are the axes (if the calculator is configured to display the axes.
1. Open the Y= editor.
2. Type in a function EXample y=2X+1 (To type X press the [X,T, Theta, n] key)
3. Press ENTER to validate the function.
4. Press the GRAPH button.
5. If you do not see a straigt line press the ZOOM button
6. Select ZoomSTD
SOURCE: Graphing Feature error message
This usually happens after the statistical graphs have been used. You should deactivate them. Press [2nd][Y=] (STAT PLOT). Select [4:PlotsOff] [ENTER]. Calculator echoes Done on main screen.
Restart your graphs.
SOURCE: Calculate Menu Problems
If you have more than one function graphed, use Up/Down to select the one you want. Press Left/Right to select the point at which you want the derivative, then press ENTER to see the value of dy/dx.
