Printer has jobs to print and printer shows ready, but nothing happens . No error msgs. The print Q has 13 jobs to print but none will print. I can go in and restart a particullar job and it shows printing , but the printer does not respond.. Shut it off and back on but still does nothing, not even and error msg. when I go into control panel and look at the printer it shows everything ok. Tried to print a test page but again no response. It seems like it should at least give some kind of error msg. Any ideas?? By the way this is not my printer, but a friend of mine.
Is your HP printer having printing problems due to incorrect printer configuration and driver installation? For the quick tech assistance, you can also go to the Printer USA Support, which is an online directory, offering the certified HP toll-free number that is helpful to directly get in touch with the technicians and get your printer problems repaired in no time. HP Printer Tech Support Phone Number HP Printer Help
SOURCE: HP Laser Jet 4350tn issue
Take the paper out of the trays and check the trays mechanism, lift the tray by hand and make sure nothing is obstructing the movement or something broken.
SOURCE: My HP deskjet F4810 printer keeps going offline
hi dear
this link for your driver
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-40457-1&lc=en&cc=us&dlc=en&product=1128296&os=228
oke....
post in me back
thks
ropp
As described by you , there might be an issue with teh spooler service of your computer , u can follow the undermentioned steps that might help you.
key the commands
net stop spooler
2. In the run (Start Search for Vista) type : c:/windows/system32/spool/drivers…look for w32x86 folder.
3. Inside w32x86, there will be folders with the names 2 and 3 (one or more of these may be absent - not a problem)
delete all of the files and sub-folders in each of the 2 and 3 folders, but not the folders themselves. Inside 32x86, there may be other folders with names starting with "Hewlett-Packard", "hphp" or something else; delete these folders also.
4. In the run (Start Search for Vista) type : c:/windows/system32/spool/printers: delete any files there. By default, this is where the print spooler stores print files.
5. Open a Command Prompt window
key the commands
1. sc config spooler depend= RPCSS
(note the space after the = but not before)
2. net start spooler
Cleaning from Registry:
1. Take backup of registry:
2. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers
The spooler cleaning is complete.
now reinstall the printer .
SOURCE: HP4000 not printing LPT1
Dear sir;I believe you can try " cold reset", that's means going to clear all data from the printer memory and sets all the defaults back to the factory settings.performing a "cold reset" resets the jetDireect configuraion. to avoid making changes to yourconfiguration, remove the jetDirect card before performing a cold reset. if possible, print a configuration page prior to performing a cold reset. this will document current settings for later reference.
to perform a cold reset;
1, turn off the printer.
2, while pressing "go", turn the printer on. COLD RESET appears briefly on the display, then INITIALIZING appears.after a few seconds, RESTORING FACTORY SETTING appears on the display, followed by OFFLINE.the cold reset is complete.
3, press "go" to return the printer online "ready " appearson the display.
Little bit complicated but is easy ,hope can take care your problem, GOOD LUCK! Let me know the resolve please!
HAVE A HAPPY HOLIDAY !!!
SOURCE: hp 2420 prints a ''job storage status page'' after each print job
If you have your software driver or print job set to save your print jobs to the printer and your printer does not support this, you will get that error and status page. Here is what the User's manual says about print job storage:
"The printer supports two distinct job-storage features that you can use to initiate printing from the printer control panel after the print job is sent from the computer:
● Proof and hold jobs
● Private jobs
Make sure that you identify your jobs in the printer driver before printing. Using default names might override previous jobs that have the same default name or cause the job to be deleted.
The job-storage features require 48 MB of RAM. For printer models that have less than 48 MB of RAM, you can add memory so that they can support the features."
