SOURCE: Homelite MightyLite 26cc Edger won't start
You have to make sure the case of the plug is making good connection against the metal on motor. Use file or sandpaper to get good connection on the plug and the motor.
SOURCE: Home lite String Trimmer Won't Start
be sure your kill switch is set to run positon and the wires from it arent grounding theirself out . Make sure your spark plug is
grnded to metal when you check for spark.(ground to head away from the spark plug hole
You may have a bad ignition module if you still have no spark or the flywheel keyway has sheared for some reason throwing it out of timing.(removal of flywheel is required to see if the keyways are aligned flywheel and crankshaft)
If your flywheel seems tight then you may be ok
not a high failure rate but it has happened.Gap your plug at .030 then.025 see if that makes a difference? keep going to a smaller gap to show you may have a weak module not able to jump a wider gap.
just a couple things to check hope this helps maybe
SOURCE: Starter on trimmer wont retract
i'm sorry to tell you this, you have to take take the hole recoil apart.either the spring is broken or the dog that holes the spring is not engaged.to fix it you have to take it apart.restring the rope,make sure the dog is catching the spring,rotate the recoil rotor to tension the spring,retie the handle and reinstall the recoil as an assembly.hope this helps,let me know if you have any questions...........
SOURCE: Brand new Homelite Mighty Lite 26cs String Trimmer
carb setting is too lean,need special tool to open,go to mower shop.This model also has problems with starter mechanism,I hope you have a warranty
SOURCE: st185 Homelite string trimmer starts then dies
I had a simular problem with mine. Most likely you have a clogged exhaust. I litterly took a nail and pushed it in and out of the muffler and it works great everytime. Hope this helps..
Kim
