My universal cable remote, nor the vizio remote will work on my vizio tv. None of the buttons work. Can turn the tv on manually. All the buttons work that is on the tv. But the remotes will not work. HELP????
We will presume you do not have two bad remotes---the fact you can operate the set manually with the buttons there suggests a problem with the remote receiver====there is a tiny infrared receiver in the front of the set that receives the signals from the remote and sends them inside the set where the correct action is taken.
Make sure if you see it (usually small black area on frame of set) it is not blocked or dirty.
Failing that you may have a bad receiver for the remote---shop repair.
SOURCE: vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
SOURCE: Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
SOURCE: Programming Cox Cable Box Remote to Vizio TV
using a cox cable remote. cant program to work cable and tv functions at the same time. please help?
Remote battery size for vizio remote with wireless sub woofer sb4021e b0
