It is a motor overcurrent issue, it can be caused by either the motor or the motor controller. you can try disconnecting the motor from the controller and cleaning the plug with contact cleaner but it doesn't always work.
Motor controller is in the base if the machine, you need to remove the lower back panel.
Just found on my very old Shacklock F&P ECS GW51S that would not spin, burnt smell from controller p/n 422742 mounted in bottom by motor. Removed and disassembled, found burnt leg at solder joint onto circuit board. Cleaned and re-soldered wire to bridge joint. Works fine. Phil S
Thanks for your reply Owen. Whereabouts do I locate the controller in the machine.
Thanks for your help Owen but it was just too much for the old machine to cope with. After 23 years of service it refused to resuscitate. Must have got got a good one out of the batch. Cheers.
