I'm trying to do simple equations with scientific notation like: 6.626 X 10 (power of -34) multiplied by 3.0 X 10 (to the power of 8) divided by 5.25 X 10 (to the power of -19). Keep getting ERROR 1 message, I have also tried resetting it.
SOURCE: scientific notation
you want to hit mode not menu and then make sure that normal is flashing instead of SCI and hit enter. so just hit mode then enter and it should be normal
SOURCE: I have a TI-30XS Calculator
One solution that you might try is to put the scientific numbers in parentheses. For instance open parenthesis, type in the first scientific notation then close parenthesis, next hit the divide key and then open parenthesis and type in the 2nd number in scientific that you are dividing by and then close parenthesis. Hit enter or =. I'm not sure if this will fix your problem, but it is worth a try.
Use the EE key
1.234[EE] [(-)]65 [ENTER] 1.234 times 10 negative 65 =1.234E-65
The (-) is not the regular (bigger) minus sign.
Hope it helps
SOURCE: Inputing scientific notation into my calculator
1. To convert a number to scientific equation, use [2nd][Sci]
Exemples 12345 [=] screen shows 12345 Then [2nd][Sci] coverts it to 1.2345 ^04 to the power 4.
2. To enter directly a number in scientific notation (e.g. -1.2345 X10^(-65) a very small number) you use the [EE] key 1.2345[+ /-][EE][+/-]65 shows as -1.2345 -65
1.6X10^(-19) 1.6[EE][+/-]19 shows as 1.6 -19
Hope it helps
SOURCE: HOW DO I CHANGE MY MODE TO REGULAR MATH EQUATIONS
Press [SHIFT][MODE][6:Fix] and press a numbetr between (0--9). The number you select will be the number of decimal places your results have.
However if a result is smaller than 0.001 it will be in scientific notation.
Hope it helps.
