Kenmore Elite 45986 Front Load Washer Logo
Lea Ann Reitzig Posted on Sep 11, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore elite 44832 front load washer troubleshooting F11 c01 c02
I followed the f11 troubleshooting test cycle for c00-c08, my washer did c00, then c01 had water running in and before going to c02, f11 appeared again. where can i find what the c01, c02, etc mean? or how to repair?
  • 2 more comments
  • BIGBOYPOOH Mar 12, 2009
    I TURNED THE WASHER ON AND IT SHOOTS THE SOAP IN AND STOP AND START TO FLASH F11
  • kimsheldon May 11, 2010
    The code that come up on my front load washer is a F then an H what does that mean?
  • Anonymous Mar 22, 2014
    the troubleshooting guide, does not address this
  • Anonymous Mar 23, 2014
    Test doesn't pass c02
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 17, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1613
Points
Was there ever a post back for this problem? I have the same issue, and I tried replacing the central control board, but it is still giving the F11 error. I follow the troubleshooting guidelines, but it never makes it past C01. I suppose the next logical step is to look at the motor control board and then the motor.
Anonymous
Level 3:
President:
  • Master 878 Answers
  • Posted on Sep 11, 2006
Anonymous
Master
Level 3:
President:
Answers
878
Questions
Helped
1202195
Points
3312
Leaann, F11 is a serial communication error. Information between the central control and the motor control cannot be sent correctly. C01 through C08 is just the test sequence: 01=fill by cold water, 02= dispensor motor, 03=fill by hot water, 04=drum rotates clockwise, 05=heater on, drum rotates, 06=drain pump actuated, 07= drum rotates counter clockwise, 08= high spin. You are recieving a fault before the test can complete. Check your owners manual for warranty information on your main board and see if you are covered. You can remove the top (3 screws in back and slide back) and check the harness. It will be the fourth one from the right, unplug and reset. I think you have a main control board issue here...Catriver..post back.
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
if its a Kenmore model then this message says that the button control board has lost sight of the main control board , but its been my experience that this maybe able to be reset and it may never come back or it will not reset and the control board will need replaced (50/50)
cycling power may reset this
Jan 30, 2016 • Dryers
I have a Kenmore HE 3t front loading machine. It's 5 years old and I'm getting an F11 error and I can't complete the cycle.
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancell, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech
4helpful
The digital readout is showing f 11
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08.
Thank you !!
2answers
Just looking for that an error f 11 means
Thank you !!
Code F11
Hi, F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the pre-wash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Take care
1helpful
My washer is flashing F11- it won't finish a cycle- what is the problem?
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Wahsing machine is flashing 11 F what does that mean?
2answers
Stops on spin cycle and gives a f11 error code
8helpful
F11 error code
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancell, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Good Luck!!
Thanks
5helpful
Error codes on Kenmore Elite washer
while F09 is the water pump. It usually means something is clogging it. Take the front cover off of the washer and the water pump is located right in the middle front. Unscrew the cover to the pump and make sure there is nothing clogging it.
Alexander
vince
