My watch has model number 504-tsk085, labeled Timex 1440 Sports, and Timex provides the incorrect manual for it online. I wrote these instructions after careful experiment:
Upper left button: press to switch to a stopwatch, or...
Press and hold to enter alarm setting mode. Once flashing press again to enter time/date setting mode.
-- you can only do one or the other without exiting the setting
mode (time or alarm set).
- within the setting mode you use the two right side buttons
in obvious ways to set times/dates
Exit setting mode by pressing upper left again
Lower left button: light
Upper right button (when not setting time): reveal date while pressed
Lower right button (when not setting time): reveal alarm time while pressed.
ALSO: WHILE lower right button is pressed you can change alarm
on/off and chime on/off through the four possible settings by
secondarily pressing the upper right button repeatedly.
SOURCE: timex 1440 sports digital watch time setting
SOURCE: need instruction manual for Timex 1440 sports
I have this watch, it think its the same one, the manual on the website didnt work for me either :D
okay
To change the Alarm
Hold mode whilst on the time section.
then start/stop changes between hour and minute, adjust changes the number.
To get off that press mode again.
To change the actual Time
Go on to the stopwatch section
Hold Mode, if it shows you the alarm press mode to change to time. The seconds should be flashing, press start/stop to change between hour minute second date, and adjust changed the number.
I really hope that helped even if its a month late :D
Testimonial: "I've had several Timex watches and this one is impossible! Thanks for the help."
SOURCE: need instructions for Timex 1440 Sport watch
http://assets.timex.com/instructions/w140Instr.pdf
SOURCE: I need set up instructions for a wr50m 1440 sports watch
Visit www.timex.com/ - 12k - Cached - Similar pages
Choose: SPORTS, then SPORTS1440 and download manual.
SOURCE: How do i set the time on a timex 1440 sports
Here you go old chap:
http://assets.timex.com/manuals/
Cheers.
