There is a medium crack on hob will I need to replace the full hob or can it be repaired
Did you crack your hob by means of impact or did it happen on its own accord?
I have a neff induction hob and has just cracked in 3 directions while cooking this evening. I am just trying to determine if there is a common fault with this neff product or I am just unfortunate. Mine is under warranty and have a engineer coming on Monday, so have the whole weekend with no hob as I have been advised not to use it.
Many thanks
SOURCE: Neff T4344 hob, need instruction manual???
Try http://bshappliancecare.com/Neff/customercare.html
You can download a PDF manual for the T4344
Regards
Jon Morgan
SOURCE: Black hob top cracked in two places and small part
yes but costly.have u tryed home insurance accidental damage.
SOURCE: when turning on my 2 year old Neff induction Hob
Sadly I have no solution to this but have what seems to be exaclty the same problem. Mine is just over 2 years old and each time I use it it 'error' and turns itself off. Once I turnit on again it is fine. I'm checking the internet to see if it is a common fault withNEFF before calling them.
Anyone know a solution?
I have had two induction hobs crack on the RH bottom corner, although no one admitted to it, we thought it was our fault,so we replaced the glass top, £200 each time, but now I’m beginning to wonder if it is a fault with hobs, anyone else had similar issues.
same happened to me.
