I always use my MP145 for scaning or direct copy from it's scanner. but now I've got Massage E42 when turn printer on.
Sometimes there is no error code E42. but still scanning process no 100% completed, and E42 show up.
Scanner's light succesfully moves from right to left, but fails when moving back from left to right.
please....
SOURCE: I got E42 22 error code,it a scanner error,how do I fix it
code 42 error definitely caused by loose flat cable from the scanner down into the electronics. End of the cable does not have a plug, just solder on each element, push the cable into its socket.
SOURCE: Canon Pixma MP150 Error code E 42
Had exact same problem. Scanner light should come on at power up. Found ribbon cable connecting scanner unit to base had come unplugged from socket on circuit board. The ribbon cable is one of three found near back hinge of scanner and is hidden underneath the other two. It should drape over the edge of circuit board and then plug into small recepticle on inner side of board. I plugged it in and printer works again. Hope this helps.
SOURCE: Imagerunner 5000s scanning problem
run the network scangear utility from the start menu. Click "discover scanner", when the discovery is finished select your copier and then click apply.
SOURCE: Canon PIXMA MP145 Scanner Problem
Take it to a Canon Repair company, It has a 1 year warranty and needs to be replaced or call 1-800-ok canon.
SOURCE: Canon IR scan problem
Read the Manual (comes with Tool). If you don't have the Tool download it from the Canon site. Go to the copier and press the System/Options button next to Copy/Mailbox/Fax. Press Online. Then try scanning. Go back to copier and press Offline so can photocopy again.
Yaa, i have same problem with my print. the lcd show me EROR 42. what it means? can i have reset or close this problem?
AKU JUGA PUNYA MASALAH YANG SAMA...
PLEASE DUND....
SPA YANG TAU RESOLVING NA...!!!1
