Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
siemens flashing f23, can't open door. Do not know how to solve it
I have F23 fault on my Siemens washing machine. No idea why. It was £700 and has been useless. Very poor washing and a very long wash cycle, the clothes still have soap in them when it finishes and I have rinse them all twice after the wash cyle. It's rubbish. Never getting Siemems again. Hope it's broken so I can get rid of it.
Bottom right on front of machine. There is a red plastic strip in a little recess. Push it up. This releases the door on the Bosch logixx7. You have to dry out the base as well as f23 means that it has flooded
