This is problem with graphing differential equation. Invalid Axes error occurs if Axes=TIME or if t(time) is set as a CUSTOM axis. This is important to noticed: if Fields=DIRFLD you cannot plot a time axis. See captured image:
This graph represented differential system of equations y1'(x)=y2(x), y2'(x)=-y1(x) for initial conditions y1(0)=0, y2(0)=-1.Finally, x axes=y1(x) and y axes=y2(x)
I checked the manual and could not find an error message invalid Axis. I did find invalid ans(). This message is displayed if you used ans(1) after an erroneous result.
When using an axe the handle of the axe acts as a leveler allowing you to increase the force at the cutting edge, when you are not using the full length of the handle, you're choking the axe.
