Manual for 110.2970092 type 113-01
SOURCE: can't get top off kenmore washer model # 110 22852 100
No problem. What you want to do is this, remove the screws from the back panel first to remove that metal plate protecting the wires. Once off you need to take off the two covers on the sides of the control panel. There is one on each side, just pop them off. Once off you will see there is a screw under there holding the control panel in place. Remove the screws and that will lean back. Next take a flat head screw driver and put it under the lip of the lid on the front of the washer. I mean the lip that is about an inch down from the top on the front. Pry up and the whole lid will pop up. You will see the lid switch there held in by a screw, follow the wire to where it plugs in and unplug it and replace with the new one. Let me know if you have any other questions and if this was helpful to you. Always happy to help and good luck.
SOURCE: squeaking noise Kenmore portable clothes washer
He checked the brake? i wonder why.... sounds like u need some grease on the agitator shaft or possibly something else.
SOURCE: What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
SOURCE: kenmore 70 series, 110 washer leaks water when
Hi, You will need to change the inlet mixer valve. It is sticking open just enough to allow water to drip through it. This should be chandes asap so that it doesn't get bad enough to over flow the washer.
Here are directions on how to remove the cabinet so you can get to the inlet valve.
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
SOURCE: Kenmore He3 washer manual required
See the following Sears site for on line (PDF) manuals
http://www.managemylife.com/mmh/owner_manuals/search?query=110.45872400
