I have a BIZHUB C350 konica minolta printer, all in one, it was working perfect, till this morning I turned it on and it showed the error msg on screen " malfunction detected C-0500. Can anyone tell me please how can I fix this? Thank you.
Open the front door with the machine on, get down on the floor and look up on the right side of open area there is a slanted section in that slated section is a small hole you will not see it standing! With a small screwdrive gentle push the small switch located in side the hole that will reset the code if it comes back DO NOT RESET the copier is telling you something is wrong with the FUSER UNIT the HOT part continued reset might catch the machine on fire and that would ruin a perfectly good day. Have a qualified Tech look at it from Konica Minolta.Check this web site out for a rough idea of cost to replace the fuser.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: c350 malfunction code c-0501
After replacing the fuser unit, if you got a c0501 code you must open the front door where the toner is. On the right side (hinge side) next to the black toner and drum unit there is a plastic pannel/cover. In the lower portion of that pannel there is a hole where a trouble reset switch is loacted. With a flashlight you may be able to see it. You are ment to use a thin screw driver or the like to push the button. You do this while the machein is on and desplaying the code. As soon as you press the button the copier will clear the code and start warming up. Thats it! If you are un certin of the button placement you can take out three screws from the pannel and loosen one screw from the pannel above it and and pull the pannel off the unit. You will see the board and it is the button on the (left), as there are two of them. Tho you only have access to the one thru the cover.
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
SOURCE: Konica Minolta bizhub C350 keeps
This is a hard disk error. Time to have a tech come out and replace it.
