I tried using the remote and changing channels mannually, the numbers will change but not the channels. what could be the problem. someone please help. thanks
Need to replace to tv tuner.its defective.or you buy some gudget like channel concoverter with remote..by using audio video rca jack.
A solution is to unplug the TV for 30 minutes and then plug it back in. I helped an elderly friend with her new TV purchase. Two days later the channels would not change manually or remotely. "Someone" she called explained "something" and the channels change with the simple 30 minute "reset"
Sounds like an eeprom problem or a microprocessor problem??? Also make sure the tv didnt lose its channel memory by reprogramming the channels feature in the menu. Good Luck
Menu on tv is locked. Cannot change channel number. BBC1 is 800 rather than 1 on the remote keypad.
