SOURCE: 9hhp craftsman chipper shredder won't start
Squirt a couple of spoonfuls of oil into the spark plug hole to increase the compression as it has been sitting so long. Also squirt a little starting fluid into the carb. and give it a shot I think it will start. Hope this will. donnyb60
SOURCE: Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
SOURCE: I need a gas tank for a Craftsman 242-27006
go to http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears type in your model look through the pictures and you should be able to find the part number and sears can order it for you.
SOURCE: I have a mtd chipper shredder that's been idle for
The unit could possibly have carburetor issues after being idle for so long. For a start, add maybe some solvent to the fuel to attempt varnish removal in the carb without taking it off the engine. I suggest using a dose of the Chem Tool Berryman B-12 in your fuel mix. It is pretty strong and if you are lucky, it will enable the engine to run. If not, carb removal and rebuild will probably be required.
