Clasp is not firm
Yes it can be. Take it to a reputable watchmaker and they should be able to adjust your clasp. Usually what happens as a watch is worn for a few years the little brackets that lock the clasps down start to push outwards. so they are not fitting snug against the lock bar of the clasp. A watchmaker should be able to use a jeweler pliers to adjust them back to normal. costs about 15 dollars.
SOURCE: Need double link for mini Ebel Classic Wave Watch
Unfortunately you will not be able to buy links anywhere else exept Ebel. You can try to find them on eBay, but it may take years and even then there is no any guarantee thet you will find the right links.
The best way is to contact Ebel and ask them if they can supply any links needed. Visit this link:
http://www.ebel.com/#Stores_Service_Centers
Choose the way you want to contact them or the nearest srevice center.
Do not forget to rate, please.
SOURCE: The folding deployment clasp on the bracelet/strap
The newer straps on TAG are generally wider than the professional series and the cost of a new genuine TAG heuer clasp or bracelet may easily exceed the costof buying an entire watch of that series used.
I recommend searching for an after-market strap/ buckle usuing your case back numbers as the search criteria.
Testimonial: "Thanks - I'll try that!"
SOURCE: The clasp broke from my Fossil watch. Can the
mcdevito75 here, Without seeing the watch it"s hard to tell, but I would figure the clasp could be repaired, but the cost may equal a new band and clasp. Look for a small watch repair shop in your area and compare repair cost of the clasp with that of a new band.
